Yes, that chip controls the fuel & timing maps! It designed for a different 911 3.2 market/application, NOT for the U.S. A post up-thread provides the correct Porsche U.S. chip. Again, it's a 10 minute effort to change the chip, and then the DME ECM becomes a stock 1987 U.S. Porsche DME ECM.
Dave Last edited by mysocal911; 06-20-2025 at 08:20 AM.. |
Blackstone Oil Analysis Report
Two samples were sent in at the same time. Was used oil from the case and fresh oil from Motul’s oil jug. Both samples were packaged in Blackstone’s provided, individual containers. I made absolutely sure the correct input sheet went with its related oil sample. Received is one Report for the 2 paid for. With “Diesel Engine Oil” being noted as the “Oil Type & Grade” for this analysis... doesn't suggest a good fit. “Laboratory...” am thinking a high level of precision should exist in lab work & docs so there is no doubt in the skills applied. ![]() “Comments…” Reading this it appears they know two samples were sent in for testing. But seems they’re not clear on what is used oil and what is new. Below, their data for who knows what or whose oil---I show this only so their reporting format can be seen. I’ll be calling Blackstone later today to sort things out if that's possible. Will update. ![]() .
Karl ~~~ Current: '80 Silver Targa w /'85 3.2. 964 cams, SSI, Dansk 2 in 1 out muf, custom fuel feed with spin on filter Prior: '77 Copper 924. '73 Black 914. '74 White Carrera. '79 Silver, Black, Anthracite 930s. |
SWB 912 - G50 Carrera - 997.2 911 Turbo - 958.2 Cayenne - 9Y3 Cayenne GTS SOLD: 958 Cayenne Turbo S - 997 Carrera 4S - 957 Cayenne Turbo Workshop Coordinator at Ehrlich Motorwerks instagram.com/patrickossenkop ehrlichmotorwerks.com |
the DME ECM becomes the U.S. version 911.618.111.05, 0 261 200 050 Please post an image of the sticker on your DME ECM.
Dave Last edited by mysocal911; 06-20-2025 at 10:42 AM.. |
I'm very interested in how a Euro chip would negatively affect his city MPG. His car isn't stock. We know it has cams and SSIs without catalytic converters. I don't recall seeing the compression ratio listed but we know it had machine and cylinder head work.
Time for guessing is over!
Dave Last edited by mysocal911; 06-20-2025 at 10:43 AM.. |
Yeah ok, that's not a Euro chip. It's a stock chip commonly found in in all US and Canadian 85-86 3.2s. Quote:
The 082 DME ECMs used a 8K chip (bytes - 64K bits). Laughable isn't it? The OP's problem is NOT the DME ECM electronics, it's the chip being used! The 180 chip is not the correct U.S. OEM chip provided in 911 3.2 vehicles sold in the U.S. by Porsche dealers in '80s. Selling the OP anything other than a simple EPROM chip change is a waste of money! This is the Pelican Parts Forum. Let's post honest info to its members.
Dave Last edited by mysocal911; 06-20-2025 at 11:23 AM.. |
Steve W.is here ,let me get a beer;-))))))) was wondering where you were so long Steve;-)
Ivan
1985 911 with original 501 645 miles...807 319 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. |
![]() Back to the subject at hand, I don't know why you continue to insist the 180 chip is a Euro chip. I have dozens of them here pulled out of US boxes from probably the 2000 3.2 DME's I've had serviced or repaired over the years. I'm so certain of this I'd be willing to bet pink slips on your 3.2 against any of my cars. Wanna bet? |
Karl, I spoke to these guys. They'll send you a no-charge 302 U.S. Porsche OEM DME ECM chip;
https://www.systemsc.com/
Dave Last edited by mysocal911; 06-20-2025 at 05:45 PM.. |
This could be interesting!
![]() Ant. Quote:
"But instinct is something which transcends Knowledge We have undoubtedly certain finer fibres that enable us to perceive truths when logical deduction or any other wilful effort of the brain is futile" Nikola Tesla |
Ivan
You need to remember the orientation of the chip in the socket (notch of the chip). ![]()
Dave |
Just for a bit of clarity on the chips fitted to Euro, or in my case UK DME/ECU.
Hope this helps. Ant. ![]()
Where is the image? This is to match the present EPROM PN (xxx 180) with the Porsche part number on the lid.
Dave |
Thread Tools | |
Rate This Thread | |
