![]() Octane aside, and not concerned with when this text says "explosion" occurs (I believe ignition begins BTC with peak expansion occurring shortly after TDC), any "less mpg" comment gets some attention. In this case, snip raises a timing question. Problem with timing being off here is the engine's performance... Not a moment of hesitation through all rpm, and pull is strong to redline through all gears. Given engine performance, O2 readings, and spark plug color, can we rule timing out completely, or is it a consideration in the least? Ant... no worries about hijacking ![]() Status on progress... Looking at wheel wells and brakes for friction is delayed. Weather's not cooperating. Rain. And can't do what needs doing in condo's garage. Association rules don't support raising cars onto stands---anywhere on the property. Rushing it in the condo, possible but not going there. I get away with breaking the rules to a degree... want to keep that program on the menu. All the input provided from each of you is highly valued. Know that this "project" is not done until the answer---the solution---is found. .
Karl ~~~ Current: '80 Silver Targa w /'85 3.2. 964 cams, SSI, Dansk 2 in 1 out muf, custom fuel feed with spin on filter Prior: '77 Copper 924. '73 Black 914. '74 White Carrera. '79 Silver, Black, Anthracite 930s. |
Hey,
I wanted to add my $.02, how are you measuring the distance travelled? Are you using google maps or the odometer? On my 1977, the odometer is slightly delayed, meaning when I start the car, the speedometer is working however it takes several miles for the odometer to start working. I wanted to make sure you weren't seeing the same type of behaviour on your car.
Kevin 1977 911 S Targa |
SWB 912 - G50 Carrera - 997.2 911 Turbo - 958.2 Cayenne - 9Y3 Cayenne GTS SOLD: 958 Cayenne Turbo S - 997 Carrera 4S - 957 Cayenne Turbo Workshop Coordinator at Ehrlich Motorwerks instagram.com/patrickossenkop ehrlichmotorwerks.com |
Thanks, I missed that post!
Calculating city MPG is not that easy, driving habits, length of trips and stop and go frequency is different for every driver. But even 12MPG is not so good.
Highway driving is far more predictable to compare, typically the 3.2 can see 24-28MPG depending on how well it's running. Has anyone else ever tracked city MPG? I'm just curious. But the OP is stating that prior to rebuild he got far better MPG in the city, as I recall around 16MPG but after rebuild it's currently at 12MPG.
Sal 1984 911 Carrera Cab M491 (Factory Wide Body) 1975 911S Targa (SOLD) 1964 356SC (SOLD) 1987 Ford Mustang LX 5.0 Convertible |
I check it every time I fill up, my car is a 3.0 so not exactly the same but close enough. It’s pretty consistently in the 17 mpg range every time I fill up. On road trips where I’m primarily on the interstate it seems to be 26 mpg. For a while I was writing my miles on receipt and shoving them in the glove box every time I got gas but I quit that after a year or so.
the funny thing is in my ownership of my 911 for 29 years , i have never ever really worried about the fuel consumption_ if someone would ask i`d say,i do not know nor care.I just go fill it up(for long trips only) half a tank a go for drive...
Ivan
1985 911 with original 501 587 miles...807 226 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. |
Lots of WAGs being floated here, but most have already been addressed or are not relevant - octane doesn't affect mileage to the degree believed, but added undisclosed percentages of ethanol does.
Someone please send Discseven a known good, working DME to swap with his existing so the ECU/fuel driver circuit can be ruled out as a cause of the unusually large disparity between city and highway mileage. |
It is interesting to see just city driving. I’m not sure if I have ever done a tank with just driving around a town stop and go without some freeway driving.
I get to third gear very quickly in town and even in a 40 mph zone will probably select fourth gear. When my car was stock CIS and doing normal around town and using freeways too, I would see about 19 mpg and on long trips could get 27 mpg. Maybe try driving around in a normal fashion using freeways and running errands in town on one tank and see what your combined mpg is?
Rutager West 1977 911S Targa Chocolate Brown |
If my car suddenly had an increase in fuel consumption I would sure want to recognize it and resolve whatever issue might be causing it before it led to additional problems. |
In my case, same engine different continent;-)..consumption still the same.. Ivan and yes the gas has to go somewhere...in Karl case
Full Send Society
The gas isn't going anywhere except into the combustion chamber where it's burned effectively resulting in desirable and predictable lambda/AFR.
The premise of the question was that the gas was disappearing somehow- either it was going out the muffler as unburnt fuel or leaking form a hose, etc... all of those have been ruled out. Drag and resistance has been largely ruled out (and I suspect Karl will pursue this further and find negligible resistance if any). I asked about timing but had no clarification- Does the stock timing for a 3.2 play well with the timing for 964 cams? Suggestions to swap out the DME are great but ultimately there's no evidence of unburnt fuel. It's all being burned... Therefore the fuel is not missing- we know where it went. City driving kills MPG, maybe these cams give a lot more up top and the price is down low they consume a lot of fuel... I sincerely hope Karl finds a smoking gun and this thread has a lot of fantastic diagnostic tests for posterity, but for my money, I don't think there's a culprit other than the cams.
-Julian 1977 911 S: Backdate, EFI/ITB, AC project in the works: http://forums.pelicanparts.com/porsche-911-technical-forum/1106768-when-well-enough-cant-left-alone-backdate-efi-itb-ac-more.html |
Dave Last edited by mysocal911; 06-03-2025 at 07:06 PM.. |
Cam Timing and ignition timing play a big roll in power, and therefore fuel consumption, obviously the amount of time the injectors are held open will also eat into MPG, all this will be determined by the ECU, when a car is standard, from the factory, the ECU is pre-programed to take into account the type of fuel used, compression ratio, and the timing curve needed for performance and economy, across a broad range of driving situations etc, if you change anything in the chain be it cams, or cam timing, or compression ratio or even different types of fuel, the ECU must either learn these changes and adapt, or it must be re-programmed to best take advantage of the changes.
Ant.
"But instinct is something which transcends Knowledge We have undoubtedly certain finer fibres that enable us to perceive truths when logical deduction or any other wilful effort of the brain is futile" Nikola Tesla |
I haven't read the whole thread but I suspect an air leak, has a smoke test been done? I have a 2010 Cayenne GTS that went from highway 17 mpg (driving nicely) to 12-13 after I changed the starter motor and introduced an air leak buttoning everything back up.
Tru6 Restoration & Design |
SWB 912 - G50 Carrera - 997.2 911 Turbo - 958.2 Cayenne - 9Y3 Cayenne GTS SOLD: 958 Cayenne Turbo S - 997 Carrera 4S - 957 Cayenne Turbo Workshop Coordinator at Ehrlich Motorwerks instagram.com/patrickossenkop ehrlichmotorwerks.com Last edited by Mr. Merk; 06-04-2025 at 07:00 AM.. |
Since the engine has been rebuilt I suspect that the rebuilt engine is 'tight' so give it time to fully break in. Then you may see better mileage.
MikeD '87 930 |
I learned to read through a thread before commenting. ![]()
Tru6 Restoration & Design Last edited by Shaun @ Tru6; 06-04-2025 at 07:48 AM.. |
