finally adjustable Bilsteins
Wow…..$$$$….even compare to my Ohlins Road/Track my 996TT.
Nice edition to the aircoled market though.
Chris - Insta @chrisjbolton 1975 911s Insta: @911ratrod steel wide body, 3.6 conversion 1989 911 Carrera 25th Anniversary Ed (5th from the last car to ever leave the original Porsche factory assembly line) 2001 996 Turbo - ~54k miles |
Not vastly different in price vs the K3 V3’s w/ raised spindles. Easy $5.5k for the set too.
1978 911 SC (3.2SS, EFI, 993SS cams + the trimmings) Dynamic Comp Ratio calc: https://dcr.questionable.services/ • Gearset & Ratio calc: https://ratio.questionable.services/ |
(man/dude)
Whatever flavor you favor, add +25% for tariffs...
Heavy Metal! Part Deux - The Carbon Copy Project Heavy Metal https://tinyurl.com/57zwayzw (SOLD) 85 Coupe - The Rot Rod! AX beater Quality Carbon Fiber Parts for Classic 911s: instagram.com/jonny_rotten_911 |
There's always coil overs and a GT3 front if you want to go that route.
I'll leave these here. Allegedly, Nitron's offering is "coming soon," replete with single or double adjustability and different height, swappable, steering arms depending on which spindle height you choose...
![]() ![]() ![]() Also, rumor has it that Eisenlohr Racing Products is in R&D for a G Body offering. God bless America, it's an embarrassment of riches.
Frank Amoroso 911 M491 / M470 coupes: 1987 GP Wht / Blk "Apollo" 1987 Gemini Blue / Blk "Gemini" 1989 GP Wht / Blk "Vents" |
I'm looking for an inverted monotube gas shock at least 30mm raised spindles and or shorter body adjustable height steering knuckle digressive valve stack, high pressure blow off is a plus adjustable valving is a plus all the available shocks I have seen offer some of these features, none offers all of them, it's seems odd to me that for far more plebian cars these features are all available the Bilstein b16 g series shocks seem to be right there except for spindle height and steering knuckle height which can be fixed got links for the Nitro and Eisenlohr products? Cary & co. seem to be working on double arm 964/993/996/997 front ends these days ![]() They also did a double arm for G series 91 but I have no info on it
If we are in that price range, we use MCS www.motioncontrolsuspension.com We talk with their team about car weight (corner weight) spring rate, desired use of car etc... and get a custom set of dampners...
We have done a couple G-body cars and countless later watercooled platforms and the products are fantastic. Cheers
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
The machining could use some finer finish passes but that is clearly a far from finished part. Not sure how I feel about the bolt on nature of the spindle and toe link arm..... cheers
Titanium User
Buy some Titanium Lug Nuts! http://forums.pelicanparts.com/porsche-911-used-parts-sale-wanted/1032311-fs-titanium-lug-nuts-studs-v2-0-a.html ig: @ti_porsche_products |
Nitron estimated price is ~$6,500. Quote:
As seen at ERP's Air|Water 2025 booth... ![]() ...The upper A-arm mount is pretty slick, but I can't imagine many 993 owners will be cutting up their chassis for it. OTOH, I've driven a 993 with, among other things, ERP's RS uprights, on the road and at the track, and I'd be DELIGHTED to have that setup on a 993, if I can ever afford one. ;-) ERP upright (a.k.a. legit suspension p0rn) slated for a 964 RS... ![]() Quote:
Note the silver fitting near the bottom of the body. That's for the double adjustable version's external canister. The single adjustable version will not require a remote reservoir.
They had a teething problem w/ the early bearing retainer plate bolts, looks like that has been rectified ![]() right now the MCS look like the best option for a G series 911(even though mine is really an I series), I was just shocked when I ran across the PS10 Bilsteins for G series, in the 964 up world they are a very nice street option, a couple of steps down from MCS
Had Nitrons on my exige years ago. Great quality wouldn’t hesitate to try out their Porsche stuff
Have you guys seen what NTP in Europe sells?
https://www.ntp.it/english/motorsport/marken/porsche.html 3-way adjustable Bilstein dampers in rebound and bump (low- and high-speed) Bilstein PSS10 front shock absorbers for the Porsche 911 adjustable in rebound and bump with 10 clicks. Complete new front strut from Porsche Original. With 40mm cartridge and Bilstein PSS10 regulation incl. coil over system and specific setting on-demand and also travel for the use what the customer needs (street-use, race, rally etc.) Bilstein MDS shock absorbers rear – with 2-way adjustable in rebound and compression or also with the Bilstein PSS10 System. ![]() ![]() ![]() ![]()
‘70 911E ‘82 911 SC Targa ‘86 944 Turbo ‘90 OM606 Swapped SWB 300GD IG: @JackSchroederCreative |
For the G-Body cars, those PSS10 would be like all other PSS10, a crude 2 way, in that they adjust compression and rebound together, but not independently. Fine for street use. But be prepared for a failure, and then a lack of support while your car is down...
![]() Cheers
A little bit rough as well …..
for a car that's 60+mm lower than stock how long a shock body do you recommend? how does MCS handle steering knuckle height adjustment, single sheer, double? I see that they have 2 options cartridge that uses donor spindle 2way new spindle 2wnr What advantage does the new version offer? i
Apples to Apples....
2WR are remote canister. Also available is a 2WNR, no remote canister. You can talk to an engineer about your car's weight and spring rate and the way you want to drive it (track, performance street, or a mixture of both, even talk tire compounds). Then get a custom valved set up vs an off the shelf product. Kinda like when Jack French was still alive and working at Bilstien NA and you could get custom help.... For your 60mm specific requirement, talk to them. Or have a dealer talk to them on your behalf. Cheers
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 Last edited by Jeff Alton; 05-12-2025 at 08:43 PM.. |
