How screwed am I ?
Ignition switch steering lock assembly.
You have a challenge, but not impossible fix.
Unless you are built like a gymnast, remove the seat and the steering wheel to have easy access to the back of the dash. As a old fat man, it was way easier to remove them than trying to squeeze in. Both are not hard to remove. And maybe some folded up towels to use as a pillow for you head.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
well, define screwed..If this is the one you just removed ..you are doing fine- just need to buy new one,or get old used and change the tumbler for your original key
Ivan
1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. |
Yes, that is the part I removed. Ok, maybe not so bad just have to figure out how to extract the tumbler.
there is a pin which holds it in place..what i do is ..i cut with a thin saw sideways to it.So i would be able to pull it or pry it out .The cut itself does not damage the ignition switch.if you cut it cc 2mm deep so you are able to remove the pin..i hope this helps
Ivan
No experience with this fix on a 911 but ... the pot-metal on these switches is so weak : (a major but rare, disappointment of materials used on these cars) My '71 914 had this same failure it. Part has similar build-quality. Found out it was a 'one year only' replacement part by ordering the part for all other 914's in that regard with a 911, you are probably easily able to get the right replacement part - the first time. Getting it back in there tho, is as tricky ..and a bit more difficult as taking it out. By having the broken part out and on your workbench you are ahead of the game. One of the most difficult 'fixes' ever on my simple 914 -working upside down below with the steering column dropped ...at least on the 911 the access is a bit easier.
jt '83 SC '96 M3 6 Bicycles 2 Sailboats Last edited by Kraftwerk; 07-14-2025 at 10:00 AM.. |
Ivan
Ugh, same happened to me.
I cant remember what i did to fix it, but i remember that part being so expensive i had to find another fix. Good luck.
81 SC 3.8 Conversion 2017 Macan S INSTAGRAM @tail_spinz |
jrblackbox, thanks for posting that most excellent repair link.
1986 Targa Guards Red 2021 MT09 SP |
Thank @Determined |
