1977 Carrera 3.0 gap questions
Hi anyone know the spark plug and points gap sizes on a 77 Carrera 3.0. Not sure if the same as a US 2.7 or not.
The calvary is coming over Sunday to take a look at might problem, woud be nice to have correct setting for them.
Thanks,
Old 08-10-2005, 11:53 AM
Bump.
Old 08-10-2005, 01:57 PM
Bill Verburg's Avatar
Same as 2.7
Bosch dist 38&#186 &#177 3 /.35mm gap
Oem plugs were Bosch W260 T2 (0.7mm gap)
I also used w/ good luck BoschWR5 DPand later ND W 24 ES GU all at the same gap.
You can blueprint the plugs for a tad better spark by rounding the ends and unshrouding the center electrode, if you do that a slightly bigger gap will work assuming the rest of the ignition system is optimal
Bill Verburg
Old 08-10-2005, 02:27 PM
Thank you Bill.
Old 08-11-2005, 03:55 AM
