| Registered Join Date: Feb 2002 Location: Scituate, MA
				1977 Carrera 3.0 gap questions
			Hi anyone know the spark plug and points gap sizes on a 77 Carrera 3.0.  Not sure if the same as a US 2.7 or not.   The calvary is coming over Sunday to take a look at might problem, woud be nice to have correct setting for them. Thanks, David | ||
|  08-10-2005, 10:53 AM |
			Bump.
|  08-10-2005, 12:57 PM |
| Moderator |
			Same as 2.7 Bosch dist 38º ± 3 /.35mm gap Oem plugs were Bosch W260 T2 (0.7mm gap) I also used w/ good luck BoschWR5 DPand later ND W 24 ES GU all at the same gap. You can blueprint the plugs for a tad better spark by rounding the ends and unshrouding the center electrode, if you do that a slightly bigger gap will work assuming the rest of the ignition system is optimal
				__________________ Bill Verburg '76 Carrera 3.6RS(nee C3/hotrod), '95 993RS/CS(clone) | Pelican Home |Rennlist Wheels |Rennlist Brakes | | ||
|  08-10-2005, 01:27 PM |
			Thank you Bill.
|  08-11-2005, 02:55 AM |
