Burnin' Rubber
Koizumi's Avatar
Tach issues
Intermittent Tach. I’ve taken it apart and cleaned up the guts with deoxit, scraped contacts clean etc.
My question is… If the shift arrow light works, does it mean the unit is receiving a working signal? I’ve fiddled with the black/purple wire but it doesn’t seem to make any difference. The Tachometer needle works sometimes and sometimes it’s dead.
If the unit is getting a signal due to shift light working, can I rule out external connection issues? Wouldn’t this lead to bad or crumbling solder joints? Or a wonky capacitor? Not sure since the tach needle sometimes works.
Signals and other functions work fine. Voltmeter indicates car runs at 14.2v-14.4v which rules out the VR. No light dimming etc.
Old 07-31-2025, 08:41 PM
There are two different wires going from the DME to the tach. The black/purple is for the tach needle. The black wire is for the upshift indicator. When the needle isn't working, tap on the glass on the front of the tach. Does it move now? Any chance you have an osilloscope? There are a few posts on here about what to look for. I believe the secret decoder is freq * 20 = RPM.
Old 08-01-2025, 04:23 AM
Yep, seems correct for the ignition signal. Three ignition pulses per engine rotation.
And for the upshift signal, I think it should be Upshift signal freq * 60 = RPM
The upshift signal is derived from the injector drive signal. One injection pulse per engine rotation.
Gilles
RoW 88 Carrera coupé
Old 08-01-2025, 04:47 AM
Remember, there's an analog (tach) and a separate digital (upshift) electronics section in the tach, either can fail not affecting the other.
Dave
Old 08-01-2025, 06:29 AM
Burnin' Rubber
Koizumi's Avatar
Tach issues
Many thanks, gents. I appreciate the wise advice and troubleshooting methodologies. I don’t have a scope but always needed an excuse to buy one lol
I took the unit apart again and inspected the joints, can’t isolate any cold joints or continuity fractures.
The tach works for a minute then stops. It’s mostly not working.
I am not one to give up but this might be the one time I have to defer to an outside repair.
Old 08-01-2025, 04:06 PM
Burnin' Rubber
Koizumi's Avatar
Can anyone recommend a rebuilder?
I live close to North Hollywood Speedometer but they’ve really gone up in price.
Cheers
Old 08-02-2025, 09:54 AM
Burnin' Rubber
Koizumi's Avatar
Tach issues
After signal continuity testing…
At the Tach:
#2 pin black/violet wire
#6 pin brown wire
I get 8.6v at idle, slightly less with throttle
Conclusion: wiring intact and volts detected.
Must be capacitor(s) in tachometer!
Tachometer works upon start-up, for 2-3 minutes until it warms up, then shuts off.
Repair time. Any suggestions?
Old 08-15-2025, 09:33 AM
Unless you want an 100% original look, ditch the pointless shift light, and have a volt meter installed when you send it to a rebuilder.
Not only does it show you voltage, it is a very visual warning to a broken fan belt and no charging. The volt meter is just great to have right there in front of you. Super easy to wire up.
The silly shift light was one a federal mandated way to show drivers how to save fuel. I know when to shift, and that shift light was just stupid.
Old 08-15-2025, 09:52 AM
Burnin' Rubber
Koizumi's Avatar
Wholly agree with your recommendation!
I have a voltmeter I installed a few years ago, it saved me from alternator failure.
I might have the tach modded as this was always the solution I wanted.
Cheers
Old 08-15-2025, 01:20 PM
Location: Just a little north of 13669/Nation's capital
Send a message via AIM to brighton911
Koizumi, looks like you are handy so I suggest going this route, it is still working 100% for me. https://forums.pelicanparts.com/porsche-911-technical-forum/1058070-tach-repair-new-easy-way.html
1986 Targa Guards Red
2021 MT09 SP
Old 08-16-2025, 04:31 AM
The tach is getting signal, but the gauge itself has an internal issue. The most bang-for-buck fix is to reflow all the solder joints on the tach board, especially where the connector pins and big components mount.
Old 08-16-2025, 06:01 AM
Burnin' Rubber
Koizumi's Avatar
I gave it another shot but failed miserably lol. Must be more than cold solder joints, etc. In the meantime, I slapped in a makeshift temporary cover. I quite like what I came up with
Old 08-18-2025, 03:09 PM
Then test the IC & the transistors.
Dave
Old 08-18-2025, 08:17 PM
Burnin' Rubber
Koizumi's Avatar
I did test as much as I could. Might be a board trace disruption that I can’t isolate?
Either way, the tach is in good hands currently. I got instrument surgeon JBell959 working on the patient.
Old 08-19-2025, 08:27 AM
I would send it to John Bell (jbell959). He did these for me. Amazing job. My Tach needle was a little slow and he explained why, what would be required to fix it etc. Very good price, amazing quality, amazing work, and very fast. Also communicated the whole way though. As you can see he also did a wonderful job on my custom graphics request and my quad gauge (built with all Porsche gauges).
Chris - Insta @chrisjbolton
1975 911s Insta: @911ratrod steel wide body, 3.6 conversion
1989 911 Carrera 25th Anniversary Ed (5th from the last car to ever leave the original Porsche factory assembly line)
2001 996 Turbo - ~54k miles
Old 08-19-2025, 01:14 PM
Burnin' Rubber
Koizumi's Avatar
Looks great!
Old 08-20-2025, 12:17 AM
evan9eleven's Avatar
+1 for John Bell (jbell on this forum.) He is the best and in SoCal.
1981 911SC restomod "Minerva"
2004 Boxster S
2021 Cayman GTS 4.0 manual "Olive"
2014 Cayenne GTS V8 (wife's lover)
The slope is not slippery; in fact it is entirely frictionless.
Old 08-20-2025, 05:45 AM
