Converting External Regulator to Valeo Alternator
Hey All. My 1967 is no longer producing a steady high enough charging voltage. When driving the green alternator light is always dim. Sometimes, when the car is just started, it will be off, but as the car warms up, the light starts to come on. Voltage meter reads 12.9-13.2 at 3000 RPM in the driveway.
Foolish me thinks, OK, this should be easy. I see the replacement on alternator voltage regulator assemblies for sale by our host. That part is in my swap-it-and see budget. However, I read rumors of older, different alternators, and I check first. Took it out and yup, external regulator (and now that I know what to look for, I identified the external regular on the engine compartment wall.) I am prepared to replace the alternator with the Valeo with the on alternator regulator, but I am having trouble finding the documentation on the wiring modifications.
For reference, My wire colors do not match the guides I have found (but I think I can figure it out based on terminals, picture attached for reference) My brushes seem good? and have good spring back . (Pic attached) And I know I have not removed the alternator from the fan or fan housing. This was just to make it easier to put it back if I don't get the parts before the drive to winter storage. ![]() ![]()
Lash
Check with our host, they sent me the procedure when i purchased an alternator with internal VR. This was on my 1980 so hopefully they have one for your 1967
Lash 1963 356 T-6 Normal Coupe 1972 911 T Coupe ..... Sold 1972 911 S Targa ...... Sold 1980 911 SC Coupe Weissach |
There's a reprint of the Porsche Service bulletin on the last page of our install manual. It's in the link at the bottom of this page below Downloads.
www.classicretrofit.com |
Coram Deo
I'm in the process of doing the same thing, so appreciate your asking and Jonny pointing. Here is a link to the pdf at Rennlist.
https://members.rennlist.com/emcon5/Tech_bulletin_1.pdf
Dru 1980 911SC Targa Petrol Blue Metallic Cork special leather Sport Seats Limited Slip 964 Cams SSIs Rennshifter 1990 250D Opawagen 1995 E220T Sportline Familienwagen 1971 280SE Beverly... hills that is 1971 Berlina 1750 Faggio |
Bringing a slightly older thread back to the top. I too am curious as to how I should wire my new alternator with an internal voltage regulator. The alternator/engine harness has a multiple pin plug that connects to the original external regulator. This includes a connection for the blue wire that exits the main car harness and runs to the dummy light. Do I now extend this blue wire straight to the alternator '61' post? What do I do with the other wires that attach to the multi pin plug? I have looked at the tech bulletin, but my simple brain is still a little confused. Thanks for any and all help.
Josh |
Lash
What year is your 911?
Lash
If our host PP does not have the procedure for a 1966 911 check out this link.
https://www.google.com/search?q=1966+porsche+911+converting+external+volt age+regulator+to+internal&rlz=1C1VDKB_enUS1167US1173&oq=1966+porsche+911+converting+external+voltage+re gulator+to+internal+&gs_lcrp=EgZjaHJvbWUyBggAEEUYOTIHCAEQIRiPAjIHCAIQIR iPAtIBCjgxNjMzajFqMTWoAgiwAgHxBQk4ASfJouru8QUJOAEn yaLq7g&sourceid=chrome&ie=UTF-8 Hope this helps Lash
| Tags |
| alternator , valeo |
