sunroof rattle when open
I had my sunroof out to deal
with a broken bracket, even before the fix I had a rattle from the sunroof when it’s open, either fully or partially open. I am familiar with the height adjustments, four (2 on each side) on the front of the sunroof panel under the headliner and the 2 height adjustments on the brackets (1 on each side) on the sliders.. could an adjustment at those adjustable spots help stop the rattle. The sunroof does have wiggle room when i pull up and down on it with the roof slightly open. Am i missing glue-on sound pads? |
have you checked if the plastic sliders are worn out? one of my was basically gone and rubbing on metal (red arrow) which allowed it more play since it could move vertically.
i’ll check it. thanks
