78 distributor rotation direction
I have a 78 engine on a test stand and I want to run it on the stand prior to putting it in the car. This is my first sc engine. Right now I am diagnosing a no spark condition. So I was checking the distributor with the cap off and the rotor rotates counterclockwise, both with the starter and by hand with a wrench on the alternator nut. The Bentley clearly states that rotation is clockwise. There is an arrow on the distributor body that points ccw, and the sticker under the engine lid indicates ccw.
I did a search on this forum, and there is one thread back in 2002 that indicates ccw rotation in sc's is correct, but there are lots of other threads that indicate cw is the correct rotation, but not specifically for sc's. The dist number is 0 237 304 06/PGUF6
Anyone? Thanks in advance!
Old 05-15-2016, 04:53 PM
Mark Salvetti's Avatar
That is pretty well known error in the Bentley. It should read CCW.
Bentley has an update on their website: https://wiki.bentleypublishers.com/pages/viewpage.action?pageId=12910636
Mark
1979 911SC Targa
Old 05-15-2016, 05:20 PM
ROW '78 911 Targa
timmy2's Avatar
78-83 SC' are CCW.
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 05-15-2016, 05:21 PM
Banned
has there ever been any explanation as to why this was done for the SC? more trivia than required knowledge I guess...
Old 05-15-2016, 06:15 PM
VFR750's Avatar
It is an odd thing. Maybe someone screwd up the drawing and too many parts were ordered before they figured it out? I'd be interested in knowing too.
Mike
'82 911SC, SSI, 22/29 tbars, 22F/22R Adj swaybars, Bilstein Sport, Elephant polybronze & monoballs, Cambermeister bar, turbo tierods, Carrera oil cooler, front brake cooling ducts, Sparco Sprint 5 & Recaro SRD PAX seat, Teamtech harness, DAS Sport rollbar.
Old 05-16-2016, 02:34 AM
This design change cost me an air box last week. The bright side of it is that I get to drop my engine again so I'll be a pro now.
Old 05-16-2016, 04:11 AM
Thanks for the answers and the discussion. Hopefully, if this question occurs again, this thread will pop up during a search.
Old 05-16-2016, 01:10 PM
Senior Member
Jdub's Avatar
These distributors also feature a pinion with a unique pitch to it if I recall correctly. It just means you always want to retain your OEM distributor with the early '78's and be sure the pinion matches its counterpart in the engine.
'78 Targa in Minerva Blue
Old 05-16-2016, 02:29 PM
CW or CCW
Could it be so simple as placing the wires in the opposite direction? Pinion gear will not interchange?
How why would the guys have done this?
Old 10-05-2025, 02:04 PM
Porsche has a history of changing things so updates and back dates are difficult to impossible. The CCW distributor is one example.
Old 10-06-2025, 07:34 AM
