Dave Project: 1985 Porsche 911 Carrera Coupe 3.2 to 3.4L "Carina" PCA Member- Sacramento Valley region |
Steve Weiner used to claim that the rear yellow Bilstein sports were shorter than the regular green Bilstein hds, Chuck @ Elephant says not. I'll measure mine when I get the chance. I wouldn't worry about the bushing but in any event bushes can be changed. My 993 has an RSR all mono-ball suspension w/ not a spec of rubber to be found and yet is quite streetable.
Folsom/EDH CnC is a good place find more local cars... If you are willing to drive - EASY happens 1st Saturday of the month in Emoryville (basically next to Pixar) - lots of old 911s there... We are planning on going this weekend...
1986 Carrera 3.2 Coupe in Grand Prix White IG: @c.cal.porsche |
again unless you have as a min 7 & 8 either 15 or 17(16 is a tire wasteland, sort of like the Boge/Biilstein) 205/225 tire set you are largely wasting $ w/ just shocks or just t-bars where you are now wrt to shocks is sort of the worst place to be as is 6 & 7 wheels the Boge/Bilstein combo throws away some of the nice Bilstein features like upside down shock while retaining some of the worst like the linear valving w/o a blowoff provision If the car is lowered it's worse as the already short ~3.5" of compression travel is further reduced while the steering geometry also deteriorates. JMO but you need to make a choice to either of the more viable routes stay w/ high pressure mono-tube shocks for the precision and control. There are several sub routes here, i.i full Bilstein(customized or not), MCS, JRZ, Penske or go to a low pressure twin tube w/ longer travel, more comfort at the cost of less control, i.e. Koni, KW I'm not sure where Ohlins fits here as they just don't publish that info, or go really crazy w/ the newest e-control Tractive offerings
The info that you have provided is a lot to digest, but it makes sense. My original plan was to make a small improvement in the enjoyment of driving my car, since I definitely need new dampers and tires (15 year old General Grabbers on there right now). I can see that a complete suspension upgrade is going to have to be better planned ($$$$) and will have to be pushed into "Phase Two"... at least two years out for me ![]() Unexpected replacement items, such as a severely cracked fan shroud, both rear hubs and a cam housing, have put me so far outside of my budget that I must put off serious upgrades if I want to drive the car anytime soon. Using the info you have shared here, I am going to continue my research and start putting together a plan for these phase two upgrades, as they seem well worth the effort and the cost. For now, I guess I just need a replacement shock for the BOGE's and some 16" tires. I will be putting in HD rubber bushings everywhere, as well. Thanks, Dave
Dave Project: 1985 Porsche 911 Carrera Coupe 3.2 to 3.4L "Carina" PCA Member- Sacramento Valley region Last edited by 85RedCarrera; 10-31-2025 at 05:55 AM.. |
7ET23.3 & 8 ET10.6 Fuchs are a big step up, switch to 205/50 & 225/45 x16 tires for the full benefit. This is the sweet spot for 911 16s, though there are arguments for 9s w/ 245/40 in back. For the even more demanding driver there are even bigger gains to be made w/ aftermarket custom ET 15 or 17, up to 8 & 9.5 w/o going to 930 fenders whether 15 or 17 is better largely depends on the drivetrain and intentions.
