Source for Kendall NS-MP 80W90? Seems discontinued...
Ran it in my old SC. Currently refreshing the 3.2 and noticed Pelican alongside numerous other vendors no longer stock it.
Anyone know if it's gone for good or did/is it getting replaced by something else? Not looking to devolve into another oil thread. I currently have Swepco in it so yes I know there are other oils to use. |
Our host sells Kendall gear lube:
https://www.pelicanparts.com/More_Info/KENLSD7745.htm?pn=KEN-LSD-7745
-Tony Instagram: @Pablo_the_Porsche | @RuchlosRallye AchtungKraft #002 |
gearhead
1974 914 Bumble Bee 2009 Outback XT 2008 Cayman S shop test Mule 1996 WRX V-limited 450/1000 |
What are you liking for a street 915 these days? Thanks
Rutager West 1977 911S Targa Chocolate Brown |
This is the one I'm looking for and had used previously: https://www.pelicanparts.com/More_Info/KENHYP7728.htm?pn=KEN-HYP-7728&srsltid=AfmBOor9iaKzOYGS8UC5V4RCJkUDskWEnB2GrPmz8Y SxUU_75hpeFKa9 |
Looks like JEGS has it.
Walt 82SC 3.0 81SC 3.6 |
The listing on JEG’s website says 80W-90, but the bottle says 75W-90 .Is that the same gear lube?
gearhead
Same as I’ve said for a long time. Walmart Supertech 80w90 conventional gear oil in the blue jug. It’s made by Mobil. Valvoline and Catsrol also both have conventional oils still.
I recommend Swepco to my racing customers. But I don’t drive it on the street. For a few years I’ve been posting about the changes to that NS Kendall gear oil. I think it was Phillips who bought them? It changed to semi-synthetic a year or two later. I hadn’t heard it was discontinued, but it might be.
I'm not picking my nose..I'm porting my upper intake manifold. |
Can you order directly from Kendall? That’s how I get their oil.0
Ralph W Instagram @ ralphwlll 1990 C2 Cab 2006 Nissan Frontier 1986 F250 |
Further readings: https://forums.pelicanparts.com/porsche-911-technical-forum/1108783-gear-oil-recomendation-new-zealand-3.html https://forums.pelicanparts.com/porsche-911-technical-forum/1162573-green-gear-oil.html Thomas
1981 911 SC Coupé, platinum met. (former tin (zinc) metallic), Bilstein shocks, 915/61,930/16,WebCam20/21, Dansk 92.502SD,123ignition distributor with Permatune box as amplifier,Seine Systems Gate Shift Kit,Momo Prototipo. Want to get in touch with former owners of the car. Last registration in US was in 2013 in Lincolnshire/lL. |
Administrator
If the Kendall is NLA what is recommended for the early 911 boxes?
I had Kendall in my car for a long time but couldn’t find it when I changed it last spring, so I put Swepco 201 in it. My box was rebuild about 15 years and maybe 40k miles ago and feels good. Feels about the same with either oil.
'80 SC Targa Avondale, Chicago, IL |
https://swepcolube.com/products/swepco-201-multi-purpose-gear-lube/ (see on the tech data sheet in the "Technical Data" tab)
On the recommendation of Steve Weiner and Jeff Gamroth, I have been using SWEPCO 201 80W90 since I bought the car over 24 years ago. Approximately 76,000 miles later, still going strong.
Administrator
Administrator
That site has some nice articles but I'm just looking for a recommendation for a current gear oil that is correct for a 911 gearbox
That site has mentioned in the transmission lubrication pdf that the original factory recommendation gearboxes is an all.mineral SAE90 (GL5). Afaik this is valid for the elder 901 gearboxes too. Only the fillong capacity differs. Porsche filled originally Shell Spirax MB90. Thve. Re are datasheets available for this. Choose an oil with comparable data. As others wrote above the Swepco 201 80W90 is probably a good choice. It has comparable specs to the Spirax MB90.
