Power source Only hot when engine runs
I am looking for a power source that is only live with thengine running. any ideas?
74 911 s engine
Ben
Old 07-11-2003, 08:15 PM
ruf-porsche's Avatar
Output from the alternator? You may have to install a diode along the way.
Old 07-11-2003, 08:39 PM
Thats what I was thinking. I am not sure which wire I think the blue one? Or simply come off the voltage regulator?
Ben
Old 07-12-2003, 05:33 PM
fred cook's Avatar
Power Source
What if you pulled a lead off a non-switched power circuit and ran it thru a vacuum operated switch with vacuum from the airbox? That way, the circuit would only be hot when the engine is running and you won't have to rig something off the back of the alternator.
Good luck with your project!
Fred Cook,
'80 911SC coupe
Old 07-12-2003, 06:56 PM
I like that idea do you know were I could find such a switch?
Ben
77 911 3.0
75 914-6 2.7
Old 07-12-2003, 07:19 PM
Alan Cottrill's Avatar
where do you need the power?
what are you going to power?
big AL
'77 911
Old 07-12-2003, 11:22 PM
fred cook's Avatar
Cool Hot Circuit
You might try your local NAPA store for the vacuum switch. There was a company selling a system that would cause the ac clutch to cut out temporarily when at max throttle. If there is a switch that opens when put on vacuum, then there should be one that closes on vacuum. Depending on what you are powering, you also mighty want to tie the switch to a relay and pull the main circuit from the battery.
Fred Cook
'80 911SC coupe
Old 07-13-2003, 11:14 AM
Platinum Member
dad911's Avatar
how about an oil pressure idiot light sender?
Old 07-13-2003, 12:13 PM
I just need a switching power source fuel a fuel pump relay.
Ben
Old 07-13-2003, 03:11 PM
Platinum Member
dad911's Avatar
So why not on with ignition circuit like most cars? Manifold vac or oil pressure will not turn relay on to start car. Oil pressure might build while cranking, but I wouln't want to have to run the starter that long to start every time.
Old 07-13-2003, 03:16 PM
I have carbs on this car and the fuel in the bowls will start the car. I am conserned that if in a crash I could have a problem. Safety I spose. This is why I have been considering the voltage regulator for a switching source but have not recieved any conformation that this may work. I tested the regulator in my 911 without it running but key on and no power but not convinced yet I need a little first hand knowledge
Ben
77 911 3.0
75 914-6 2.7
Old 07-13-2003, 07:21 PM
Platinum Member
dad911's Avatar
There is an 'inertia/impact' type switch available for that purpose. That would also stop the engine.
Why would the engine stop in a crash on its own??
Old 07-13-2003, 07:48 PM
I have heard of those switches but I am running with an idea and I am kind of stuburn.
I just don't want gas pouring every where If I were knocked out or something
Ben
77 911 3.0
75 914-6 2.7
Old 07-13-2003, 07:57 PM
Cool
Hey Ben.
I just did a fast eyeball thru the Summit cat.. didn't find anything.. but maybe a phone call to them.. 1-800-230-3030............Ron
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 07-13-2003, 09:17 PM
Hilbilly Deluxe
emcon5's Avatar
You can score an inertia fuel cutoff switch from most junkyards. Mid-late 80's Fords came with one. On my 86 Mustang it was located right next to the latch for the hatchback, against the rear sheetmetal. It has been a long time, but I am pretty sure it was a white plastic box with a black reset button on it.
Tom
82 911SC Coupe
GTI Cup #43
Old 07-13-2003, 10:09 PM
Is the regulator hot only with the engine running?
Ben
Old 07-15-2003, 10:38 AM
Platinum Member
dad911's Avatar
If you are knocked out, what makes you think engine is going to stop running?
Old 07-15-2003, 11:01 AM
scottb's Avatar
How about an oil pressure switch like those used on aircraft? They only operate when there's oil pressure (i.e., when the engine is running). This is what they look like:
The only "catch" is that you'll have to find an adapter that will allow you to install it in the system.
1984 Targa
Old 07-15-2003, 11:09 AM
304065's Avatar
Ben,
The voltage regulator continuously measures the alternator output and adjusts the strength of the alternator field to keep the voltage within limits. If you tap into that circuit with anything else, you will change the voltage that the regulator sees, causing it to drive up the alternator's output, potentially overcharging your battery and cooking the diodes in the alternator. That's in the black wire circuit called DF. The blue wire circuit is hot with the ignition on and is the same as a switched 12V. The brown wire is a ground and doesn't do anything. And the red wire is connected back to the battery through the starter, it's hot all the time.
I admire your persistence but I really think if you tap into that circuit you will have trouble.
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 07-15-2003, 11:12 AM
Because your foot comes off the clutch. When I crashed my car backwards into a wall at a racetrack, people tell me it did some leerching before it finally stalled. The car was still in 3rd or 4th gear, and trying to run, but I was sleeping...
Without the switch, the fuel pump would continue to pump gas since the ignition is still on, but the engine is stopped. Could be a real bad situation.
Rob
1980sc
Old 07-15-2003, 01:05 PM
