Power source Only hot when engine runs
I am looking for a power source that is only live with thengine running. any ideas?
74 911 s engine Ben |
Output from the alternator? You may have to install a diode along the way.
Thats what I was thinking. I am not sure which wire I think the blue one? Or simply come off the voltage regulator?
Thanks Ben |
Power Source
What if you pulled a lead off a non-switched power circuit and ran it thru a vacuum operated switch with vacuum from the airbox? That way, the circuit would only be hot when the engine is running and you won't have to rig something off the back of the alternator.
Good luck with your project! Fred Cook, '80 911SC coupe |
I like that idea do you know were I could find such a switch?
Ben 77 911 3.0 75 914-6 2.7 |
where do you need the power?
what are you going to power?
big AL '77 911 |
You might try your local NAPA store for the vacuum switch. There was a company selling a system that would cause the ac clutch to cut out temporarily when at max throttle. If there is a switch that opens when put on vacuum, then there should be one that closes on vacuum. Depending on what you are powering, you also mighty want to tie the switch to a relay and pull the main circuit from the battery.
Fred Cook '80 911SC coupe |
Platinum Member
how about an oil pressure idiot light sender?
Political polls are often to give you an opinion, not to find out what your opinion is - Scott Adams |
I just need a switching power source fuel a fuel pump relay.
Ben |
Platinum Member
So why not on with ignition circuit like most cars? Manifold vac or oil pressure will not turn relay on to start car. Oil pressure might build while cranking, but I wouln't want to have to run the starter that long to start every time.
I have carbs on this car and the fuel in the bowls will start the car. I am conserned that if in a crash I could have a problem. Safety I spose. This is why I have been considering the voltage regulator for a switching source but have not recieved any conformation that this may work. I tested the regulator in my 911 without it running but key on and no power but not convinced yet I need a little first hand knowledge
Platinum Member
There is an 'inertia/impact' type switch available for that purpose. That would also stop the engine.
Why would the engine stop in a crash on its own??
I have heard of those switches but I am running with an idea and I am kind of stuburn.
I just don't want gas pouring every where If I were knocked out or something Ben 77 911 3.0 75 914-6 2.7 |
Hey Ben.
I just did a fast eyeball thru the Summit cat.. didn't find anything.. but maybe a phone call to them.. 1-800-230-3030............Ron
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
Hilbilly Deluxe
Tom |
Is the regulator hot only with the engine running?
Ben |
Platinum Member
How about an oil pressure switch like those used on aircraft? They only operate when there's oil pressure (i.e., when the engine is running). This is what they look like:
The only "catch" is that you'll have to find an adapter that will allow you to install it in the system.
1984 Targa |
Ben,
The voltage regulator continuously measures the alternator output and adjusts the strength of the alternator field to keep the voltage within limits. If you tap into that circuit with anything else, you will change the voltage that the regulator sees, causing it to drive up the alternator's output, potentially overcharging your battery and cooking the diodes in the alternator. That's in the black wire circuit called DF. The blue wire circuit is hot with the ignition on and is the same as a switched 12V. The brown wire is a ground and doesn't do anything. And the red wire is connected back to the battery through the starter, it's hot all the time. I admire your persistence but I really think if you tap into that circuit you will have trouble.
'66 911 #304065 Irischgruen ‘96 993 Carrera 2 Polarsilber '81 R65 Ex-'71 911 PCA C-Stock Club Racer #806 (Sold 5/15/13) Ex-'88 Carrera (Sold 3/29/02) Ex-'91 Carrera 2 Cabriolet (Sold 8/20/04) Ex-'89 944 Turbo S (Sold 8/21/20) |
Without the switch, the fuel pump would continue to pump gas since the ignition is still on, but the engine is stopped. Could be a real bad situation. Rob 1980sc Last edited by 1980SC; 07-15-2003 at 01:11 PM.. |
