c2 rower's Avatar
Anyone using the Seine Systems gate shift kit?
Any comments from anyone who has tried this kit on a 915 transmission?
Old 07-14-2003, 05:56 PM
greglepore's Avatar
Yup. Best under $200 mod you can make. If you have a later model 915, equip yourself with a Dremel or die grinder and a sharp metal cutting bit as a fair amount of metal needs to be removed from the housing. My car had new bushings from a recent trans job by PO, but I'd do them while I was in there. Took me about 2.5 hrs total, including removing the A/C switches and console.
There is a defined gate, but the spring on the 1/2 side is light enough that after a tank of gas or so you don't even notice that its there. Its enough to do its job, however.
Greg Lepore
85 Targa
05 ST3s (unfinished business)
Old 07-14-2003, 06:34 PM
we installed on on Jack Olsen's car and it works great!
Old 07-14-2003, 06:38 PM
Administrator
Jack Olsen's Avatar
Actually, I'm pretty sure I've got the Robotek. But I would've got the Seine one, if it had been available. It's a better design and a better value, IMO.
Old 07-14-2003, 06:54 PM
It's the best $150 I ever spent on my 911.
Old 07-14-2003, 07:08 PM
Ditto what Paul said AND customer support was stellar. Sherwood is a standup guy.
Mark
'88 Carrera GPW Sunroof Coupe
'82 SC Targa (RIP)
Old 07-14-2003, 07:29 PM
DByers's Avatar
I have one to install on my 901 trans. Hopefully will get to it this weekend since I recieved my 915 housing today. Anyone else try it on the 901 yet?
Dan Byers
Old 07-14-2003, 07:30 PM
I have it and like it a lot. Put it this way - I can't imagine NOT having it. Having all the slop in the shifter, well, I don't know how I put up with it. It feels like something that should have been in the car to begin with.
Chris M
1985 911 Carrera w/ 3.6
Old 07-14-2003, 07:36 PM
RSupdate's Avatar
You gotta be kidding, right???
The Gate-Shift....???? Sherwood's gate shift...????
Well i'm here to tell ya that it's the absolute best value for improving the overall feel of the 915 as well as providing the best possible "notchy" feel as opposed to the "tossing a salad" amount of play that is normal to a 915.
Also it's the best value for darn near eliminating the possibility of the dreaded 5th to 2nd down shift......
I've had mine installed since last Sept and I can't see ever driving without it, and scores a 10 out of 10 with me.
odds are 1000 to 1 that you'll wonder why you didn't get one much sooner!!!!
Johnny Riz
1973 911 Custom Euro 3.2L "Sports Purpose"
'10 Subaru WRX-STi Hatch - modded.
RGruppe#152
Early 911S Reg.#335
Old 07-14-2003, 08:58 PM
scottb's Avatar
Are people using the clamp, or having it welded?
1984 Targa
Old 07-15-2003, 12:00 AM
andyu911's Avatar
Does it work with 914's side-shift trans?
Andy
-'87 Carrera -'73 914 2.0
-'06 Frontier -'02 VW Golf TDI
-'07 GT3 RS -'07 Top Kart KPV-4
Old 07-15-2003, 12:21 AM
greglepore's Avatar
Welded mine, but I have ready access to a mig. I suspect that JB Weld or similar would work as well if one removed the coating from the shift lever. It should cost you less than 5 bucks to have it welded at a muffler shop, and it only takes a couple minutes to set it up and re-remove it from the car.
Greg Lepore
85 Targa
Old 07-15-2003, 05:12 AM
I've heard others say JB Weld works great. It's on my "to do" list.
Mark
'82 SC Targa (RIP)
Old 07-15-2003, 09:09 AM
mm86911's Avatar
What's the best channel for purchasing this upgrade?
Mike - PBG, FL
'14 958 Cayenne GTS
'05 997 C2 - SOLD
'79 911 SC Widebody PCA, NASA, PBOC - SOLD
2004 NASA-SE GTS4 Champ, 2005 + 2007 NASA-SE GTS3
Old 07-15-2003, 09:22 AM
greglepore's Avatar
Direct or thru Wayne. Looks to maybe be 10 bucks less thru Wayne?
Greg Lepore
85 Targa
Old 07-15-2003, 09:31 AM
Where is that wrench?
EdT82SC's Avatar
I'm planning on doing a factory short shift upgrade and replace my shifter bushings on my '82 SC sometime in the not too distant future. The gate shifter sounds like an interesting upgrade to do at the same time, but I am a little intimidated by the "fair amount of metal needs to be removed". Will this be necessary on my '82, and if so are instructions and/or pictures of this available somwhere?
Thanks,
Ed T.
1982 911SC
Porsche Wallpaper
Old 07-15-2003, 03:22 PM
Thanks for the product support. I think it does a good job at an affordable price point for most owners.
Regarding the amount of material to remove if a factory short shifter is used with the Gate Shift kit; "a fair amount of metal to be removed", I suppose, is relative. It's really not that much. Here are two images; the first is a stock, unmodified shift housing showing the side opening.
The second image shows the opening after metal removal (with die grinder, dremel, drum sander, or equiv.) to accommodate a factory short shift kit. All other "short shift" kits do not require this modification.
Sherwood
www.seinesystems.com
http://members.rennlist.org/911pcars
Old 07-15-2003, 07:00 PM
greglepore's Avatar
It shouldn't intimidate-it's just that a Dremel grinder isn't sufficient-get a good cutter and its really cake.
Greg Lepore
85 Targa
Old 07-15-2003, 07:59 PM
Super Moderator
cstreit's Avatar
I used a Dremel to install mine, used a carbide grinding bit.
Best shifting modification I've done thus far. Much more positive shifting and confidence. Previously a missed shift cost me big time!
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Old 07-15-2003, 08:18 PM
RSupdate's Avatar
I also have the factory short shift installed, and had to clearance the side of the shift housing. I used my Dremel tool with the abrasive grinding wheel and it was no big deal really.
I afixed the new gateshift "tab" with JB Weld along with the hose clamp...worked great til I had PCA "driving instructors" behind the wheel, me being the "student" forgot to inform them that I had a gate shift installed and they were shifting like there was no tab....
They managed to bend the tab out of spec....
But the JB Weld was still holding it in place...!!! So I managed to gingerly bend it back to it's original shape, and then removed the hoseclamp, and fabbed up a new tab out of 3/32 stainless, and mounted it over the top of the orig tab, with JB weld holding it in place and the reinstalled the hoseclamp over the new double thick re-inforced tab. Now, my hose clamp has a hex head on it so I was able to really crank down on it.
Now the thickness of both the original and new gateshift tabs are identical and the gate shift tab is quite a bit beefier than it was originally.
cheers!
Johnny Riz
RGruppe#152
Early 911S Reg.#335
Old 07-16-2003, 11:13 AM
