efhughes3's Avatar
If removing front control arms, where do you put jackstands?
I'm going to be doing "major" surgery, the title question says it all as I won't be able to use the front control arm mounts to support the car.
Ed Hughes
2015 981 Cayman GTS
6 speed,Racing Yellow
Past:1984 911 Targa (Ruby), 1995 993C2 (Sapphire), 1991 928S4
Old 07-19-2003, 03:30 PM
Ed,
Place the jack stands on the welded seams behind the control arms. That would be about the same level as the rear of the front fender well openings. Place a really thick piece of cardboard between the body and the jack stands so that the sheet metal around the seam doesn't get pushed in.
Neil
'73 911S targa
Old 07-19-2003, 04:04 PM
Garrett's Avatar
Or put two jackstands side-by-side on the front welded crossbar that has that hoop on it; that way they're in the middle of the car, but still support it well, and you have access to both sides. that's how I did it when re-doing the whole front end, and you have no chance of ruining any soft metal spots.
Old 07-19-2003, 05:58 PM
Navin Johnson
TimT's Avatar
If you leave the crossmember in, its a good place to put the jack stands
'69 911 GT-5
'75 914 GT-3
and others
Old 07-19-2003, 06:09 PM
