MSD and Points or Ignitor
I have a 2.7 RS with 40 IDA 3Cs.
I am going to install an MSD. The mechanic suggested that I replace the Ignitor with Points. Is this a good idea or bad?
Old 07-23-2003, 06:45 PM
Chuck Moreland's Avatar
I'm using an ignitor with an MSD on my 73 2.4. It works well and it's great not having to deal with points and dwell.
Some people don't like the ignitor, there have been a lot of reports of DOA units. I believe most of these DOA units are actually due to the wrong model ignitor being ordered. Get the wrong one and it won't work, surprise.
Chuck Moreland - elephantracing.com - vonnen.com
Old 07-23-2003, 06:56 PM
47silver's Avatar
keep the ignitor it works better than the points in my opinion
gary
1975 911S Targa
Silver Anniversary Edition
Old 07-23-2003, 07:59 PM
Randy Webb's Avatar
Put the points in your emergency repair kit.
Old 07-23-2003, 09:06 PM
Ray 911s's Avatar
What's the Ignitor? Like a Pertronix (replaces the points)?
1977 911S
1973 Alfa Romeo GT Veloce
1997 Lotus Turbo Esprit V8
2016 AMG C63S
Old 07-23-2003, 09:45 PM
Pertronix makes the ignitor (sp). The other option is the optical trigger unit made by Crane which also should be able to trigger the MSD or Crane equivalent. Some guys on this forum have had some quality issues with their ignitor - not as many issues with the Crane, for what that's worth.
Sherwood Lee
http://members.rennlist.org/911pcars
Old 07-23-2003, 11:58 PM
I am about to do MSD and Ignitor in a '76 Euro Carrera 3. I don't want to hijack this thread, but do have one further question to throw into the mix here: Standard plug leads or Magnecor?
My leads need replacing and I would consider new standard ones if they can handle the MSD output. Any experience/recommendations?
Al G
Old 07-24-2003, 02:24 AM
Cool
IMHO, the Beru plug connector is a problem waiting to happen
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 07-24-2003, 02:49 AM
I installed Magnecors because Steve Weiner said exactly what Ronin did about the Beru connectors. The Weiner is high on Magnecors, and that's good enough for me.
Stephan
Stephan Wilkinson
'83 911SC Gold-Plated Porsche
'04 replacement Boxster
Old 07-24-2003, 05:18 AM
Nitrometano's Avatar
You can use any type of spark plugs wires that are spiral core. Dont use solid core spark wire with the MSD. I have a Braided spark plug wires and a Crane Cams XR-700 electronic ignition. I dont recomend use points unless you have a resisrtance in the positive cable of the coil or the point will burn.
1972 911T
1991 Mazda RX-7 Turbo II
Are you car loosing power? When was last time you service your fuel injectors? Dirty fuel injectors? Why no try a complete fuel injector cleaning service and return the dignity to you car. Visit www.rennsportfuel.com and we will return your injectors back to life!
Old 07-26-2003, 05:53 PM
Cool
Hi Chuck...
pwd72s just did a Pertronix install by a big rep pro.. the pro told Paul that it's either DOA, or it'll last almost forever.........Ron
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 07-27-2003, 09:43 AM
