Confusion With Leak Down Test
I have used my new leak down gauges on a TR3 and now the 911SC. The issue is, I think the gauges are not working. On the 911 test on a few cylinders I hear faint air leaking but the gauge doesn't move? Shouldn't it move even if it is slightly leaking? It is an OTC Tester.
Describe your procedures.
Porsche 2005 GT3, 2006 997S with bore-scoring Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS Disposable Car: BMW 530xiT, 2008 Mini Cooper S Two-wheel art: Ducati 907IE, Ducati 851 |
I get the subject cylinder to top dead center. Hook the air to the gauges and have the other hose screwed in to the spark plug hole. Gradually increase the air and both gauges go up to about 90. Both gauges stay steady but I can hear air escaping, I think out of the exhaust valve. Not much but enough to hear. Yet the gauge doesn't leak down....
And thanks for responding. I'm puzzled. |
Under the radar
Switch the two gauges and see if it reads the same.
Sounds like your are connecting to the cylinder before zeroing.
1978 SC Targa |
I have the same OTC set up. THis is my procedure.
Calibration: Hook up the gauge to the air line, run it up to 100 psi, you will always see a leakage even with the set up NOT connected to any cylinder. My set up is 3% leakage by itself. That number gets substracted from any measurement afterwards. If you see 100 psi on both sides, your set up is bad. Get the engine cylinder to TDC compression stroke. Screw in the line to the engine plug hole, attach the line to the OTC set up. Slowly raise the pressure to 100 psi on the input side. The output side will slowly follow but with a minor drop in pressure. Read the difference, compute the leakage percentage, substract the calibrated value. It is impossible to get both gauges to read exactly the same value. If that happens, toss it, or you have done something wrong.
It is not recommended to use 100psi
The proper in psi is 80 . then do the math from there Ian
Kermit, 73 RS clone, Just Part of the Team Chris Leydon ,Louis Baldwin ,Peter Brock ,Riche Clark Jerry Sherman ,Rob McGlade ,Donnie Deal Hank Clarkson ,Craig Waldner ,Don Kean ,Leroy Axel Gains |
Why?
regards, al
[B]Current projects: 69-911.5, Previous:73 911X (off to SanFrancisco/racing in Germany).77 911S (NY), 71E (France/Corsica), 66-912 ( France), 1970 914X (Wisconsin) 76 911S roller..off to Florida/Germany RGruppe #669 http://www.x-faktory.com/ |
I agree with the question: why not 100psi?
Used 100 psi on mine. Worked fine. BTW, I took apart my harbor freight version and swapped out a real pressure gauge and closed the orifice down to 0.04”. This is the FAA recommended size for aircooled piston engines leak down testers. |
The leak down test was developed by the aviation industry . They set the pressure parameters , if you use more pressure than 80psi you are not being fair to the ring seat on the cylinder walls.
When normal combustion takes place the pressure in the cyl is a rapid expansion of gases . When you inject a constant psi, the rings do not get the benefits of rapid expansion, just a steady pressure downward on the ring , vs the charge getting behind the ring pushing the ring outward and creating a better seal. These are not my words but the words of the Aviation industry, and also what I was taught . The leak down numbers on a nickie Cyl can, and very often are less than one percent , with a proper honing and brake in . I hope this helps Ian
Kermit, 73 RS clone, Just Part of the Team Chris Leydon ,Louis Baldwin ,Peter Brock ,Riche Clark Jerry Sherman ,Rob McGlade ,Donnie Deal Hank Clarkson ,Craig Waldner ,Don Kean ,Leroy Axel Gains Last edited by icarp; 11-10-2020 at 01:38 PM.. |
Ok. Aviation settled on 80 psi.
Agreed, can confirm that nicasil with proper honing and broken in rings results in 1% leak down. |
This is a link to the tester that I use . Numbers on both gauges, then do the math.
https://www.aircraftspruce.com/catalog/topages/atsdifferentialtesters_orifice.php I hope this helps Ian
https://rgl.faa.gov/Regulatory_and_Guidance_Library/rgAdvisoryCircular.nsf/0/99C827DB9BAAC81B86256B4500596C4E?OpenDocument
Chapter 8 80 psi is called out. But oddly they expect someone to find TDC by rotating the propellor against 80 psi. 0.04” orifice for 5” or less diameter pistons. ( that’s us) |
Caveman Hammer Mechanic
1984 Carrera El Chupacabra 1974 Toyota FJ40 Turbo Diesel "Easy, easy, this car is just the right amount of chitty" "America is all about speed. Hot,nasty, bad ass speed." Eleanor Roosevelt, 1936 |
