c2 rower's Avatar
Need to rotate face of speedometer
The steering wheel obstructs lots of the speedo range and I wanted to rotate it CCW. Is there a trick for rotating it?
Big Hooters and 911's will always be in style
Old 07-29-2003, 03:09 AM
Send a message via AIM to 82SC
grab it really hard and twist
just don't twist too hard, so you don't pull the wiring out at the back
but I've seen people turn it quite a bit without problems
Old 07-29-2003, 03:18 AM
Inky's Dad,
It is much easier to simply remove the guage by wiggling it out of the rubber gaskets (grab the guage ring with both hands (finger tips?), and wiggle left and right, left and right, until it's out. The gasket it perhaps 1/4" thick; will come out easily.)
Then you can rotate it to where all the numbers are visible, and push it back in. You can rotate it quite a bit, since this is an electric guage, and only wires are connected, not a cable. As for me, I put it so that 60 MPH is straight up (at 12:00 o'clock), and thus can see when I'm exceeding the speed limit. Anything below, it does not count.
Cheers............Andras
Andras
1983 911SC The Chocolate Kiss
1998 Audi A6 Quattro (Family Car)
2002 Audi TT Roadster (Wifey's Car)
1992 Mazda Miata (Daughter's Car)
1991 Honda VFR750F Interceptor
1982 Honda VF750S Sabre
Old 07-29-2003, 04:47 AM
Friend of Warren
Andras has given you good advice on how to turn the sppedo and tach although I'm not sure why he would put 60 mph straight up as that would give you more of a view of the lower end of the speedometer. Here is a pic of my rotated tach and speedo.
Kurt V
Old 07-29-2003, 06:46 AM
Yep, just turn the gauge. If yours is too tight to turn while in the dash then you can pop out one of the left hand gauges by pushing from behind through the trunk and then pop out the tach, and then pop out the speedo by going in through the tach hole. Don't worry too much about tearing the wiring as you can take the gauges completely out of the dash without removing the wiring, so you should have plenty of slack.
I have my gauges turned similar to Kurts, but I have the 0 mark straight down on both for uniformity.
Old 07-29-2003, 08:12 AM
i see the practicallity of this, but I hate the way it looks...
I guess if you are tracking it and your eyes are glued 100 yrd in front of you on the track it makes sense...
but seeing guages like that always makes me want to turn my head sideways...LOL
MJ
Old 07-29-2003, 08:49 AM
CHILI's Avatar
For those of you out there that will check out this thread later in life:
If you have a "cable" speedo, be careful when you rotate it. I rotated too far and the cable bound up and broke. Had to replace it, which was a PIA. The replacement cable and housing are longer, so I re-routed the cable and installed it in the rotated position.
But, it's done and I like the look. I have the Tach rotated like Kurt's photo. Easy to see when you hit redline. You don't even need to look, it's just straight up.
"I understand that you want to drive fast, it's just that I want to go faster!" Move ova please
Chad aka "Chili"
1974 Base coupe in Carrera outfit.
No A/C, no Sun Roof, no power windows. Fast and light, just the way I like it. (Sad to say, it's sold. But at least it remains with us on this board.)
My car http://www.pelicanparts.com/gallery/CHILI
1969 RSR Project. Heavy on the word PROJECT! No pictures yet. Keeps breaking lenses of cameras.
Old 07-29-2003, 02:05 PM
UTKarmann_Ghia's Avatar
Send a message via Yahoo to UTKarmann_Ghia
I rotated my oil temp/pressure gauge also so I could see the temp better. Only problem is that the temp gauge shows about 140 when it's cole because of gravity. That's ok with me since I only care about temps OVER 180
Matt
'82 911SC Targa!
Old 07-29-2003, 04:03 PM
