scottb's Avatar
Question Size Matters (For Fuse and Relay Amp Ratings)
I've just installed an auxilary a/c condenser, with a fan. The specs for the fan talk about 6.5 amps *input*. I assume they mean it draws 6.5 amps. My questions are these:
1. What size (amp rating) fuse should I use?
2. What size (amp rating) relay should I use?
Thanks for the help, guys.
1984 Targa
Old 07-30-2003, 09:41 AM
If it means the normal draw is 6.5 Amps,.... I think normal convention in the electrical business says load shouldn't be more than 70% of the installed fuse rating. In that case, I'd go for a 10A fuse. To be on the safe side, however, you might want to try a 7.5A fuse and if it doesn't blow..keep that.
Most cube relays are rated at 30A. I like the Bosch, silver-contact cube relays rated at 50A, just "because"...
You canget these from Bosch or Waytek Electric..web page in the archives.
---Wil Ferch
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 07-30-2003, 09:51 AM
Bill Verburg's Avatar
You always fuse for the wire and use wire sized to the load.
Depending on the length of the run a 10amp fuse w/ 14AWG wire. As Will said there is little penalty for using a larger relay.
Bill Verburg
Old 07-30-2003, 10:14 AM
