Seldom Seen Member
Burnin' oil's Avatar
Quiz for master mechanics
I replaced the points on my '73 911 yesterday. After replacing the rotor and the cap, I attempted to start the motor. As soon as I started cranking I heard an awful racket from the motor. It sounded like someone violently shaking a steel bucket of parts. I stopped cranking, scratched my head and tried to figure out how such a noise could be created merely by changing the points.
I read Wayne's project book and the Haynes manual but could not figure out what I had done wrong. I then inspected the motor and soon realized what the problem was. Anybody want to take a guess?
Old 07-31-2003, 12:52 PM
You put the cap on 180 degrees out of phase, if that's even possible?
Stephan
Stephan Wilkinson
'83 911SC Gold-Plated Porsche
'04 replacement Boxster
Old 07-31-2003, 12:56 PM
Seldom Seen Member
No, that wasn't it. I thought about that but assumed that reversing the cap would mean that the car would not run but that it would not cause any noise.
Why do things that happen to white trash always happen to me?
Got nachos?
Old 07-31-2003, 12:59 PM
Early_S_Man's Avatar
Porsche Crest
Did you remove the distributor to install the new points? If so, you may have put it back in 'off' one tooth on the drive gear ... it would start, but run like a bucking bronco on a couple of cylinders!
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 07-31-2003, 01:11 PM
Seldom Seen Member
Warren:
I did not remove the distributor. Try again.
Got nachos?
Old 07-31-2003, 01:12 PM
Author of "101 Projects"
Wayne 962's Avatar
I would guess that you placed the plug wires in a counter-clockwise orientation, like on the 911SC, when it should be clockwise for your car. This is a very common error, and one that I have made once or twice myself...
-Wayne
Old 07-31-2003, 01:15 PM
Seldom Seen Member
You guys are thinking too hard. Think more along the lines of bonehead.
Got nachos?
Old 07-31-2003, 01:16 PM
Were you turning the motor over using the nut on the fan to find TDC, and left the socket or spanner on the nut when you started the car?
Stu W.
76 911 turbo.
79 911 SC.
CHILI's Avatar
You forgot to push the rotor all the way on the shaft and it few off and was being beaten around inside the Cap?
BTW, I forgot to put the rotor back on once. Counldn't figure out why it wouldn't start! What an idiot
"I understand that you want to drive fast, it's just that I want to go faster!" Move ova please
Chad aka "Chili"
1974 Base coupe in Carrera outfit.
No A/C, no Sun Roof, no power windows. Fast and light, just the way I like it. (Sad to say, it's sold. But at least it remains with us on this board.)
My car http://www.pelicanparts.com/gallery/CHILI
1969 RSR Project. Heavy on the word PROJECT! No pictures yet. Keeps breaking lenses of cameras.
Old 07-31-2003, 01:17 PM
Seldom Seen Member
Way to go Stu. You sound like a man that feels my pain.
Got nachos?
Wayne 962's Avatar
Left your screwdriver leaning against the blades of the fan? Forgot to tighten the points plate? Dropped something into the area where the fan meets the pulley?
All big bonehead things there...
-Wayne
Old 07-31-2003, 01:18 PM
Seldom Seen Member
Stu got it. I left a 1/2 inch drive ratchet on the fan bolt. Its a wonder I can make it through a day . . .
Got nachos?
Old 07-31-2003, 01:20 PM
Woohoo!
Winning the quiz for 'silly mistake of the day'
I have not done that one, but nearly have several times.
Hope no damage was done.
Stu W.
76 911 turbo.
79 911 SC.
Old 07-31-2003, 01:23 PM
Zeke's Avatar
While working on the motor, I saw a plastic cap for a paint spray can or carb cleaner laying in there. That would have been nice in the fan. A thorough once over at the finish of each job needs to be routine. I haven't left too many tools in the engine compartment over the years, but a few. About half of them I never saw again.
Old 07-31-2003, 02:45 PM
Banned
Dropped a wrench in the super charger?
Old 07-31-2003, 04:52 PM
