Montana 911
k9handler's Avatar
Send a message via Yahoo to k9handler
engine drop...so close!
I was able to get started on the engine drop today so I can install the new clutch...and so far I am doing ok. Most of the wires and connections are pretty well marked and color coded, and the engine is down about 5" and just about seperated from the tranny. This is where I am stuck.
The car is on a lift, and the tranny is being supported with a floor jack. The engine is being supported by a pallet on a fork lift...but I can't get the two things apart. The fan hits the rear of the car if I try to angle the engine, and the bolts on the tranny just won't clear.
Ideas? My only thought is to drop the tranny as well, even though I really don't need to.
Thanks.
H.D. Smith
2009 997.2 S 3.8 PDK
2019 Ford Ranger Lariat FX4 Baby Raptor
2019 Can Am Renegade 1000R XC
2020 Yamaha YFZ450R
Old 08-01-2003, 12:17 PM
I would drop the tranny as well. Also easier to fit the engine.
Peter
'13 981S
'73 911T
'05 996 4S cab, now gone
'70 911S Targa, now gone
Old 08-01-2003, 12:52 PM
Friend of Warren
Just drop the tranny. You are only talking about another 30 minutes of work to disconnect the mount and wiring.
Kurt V
Old 08-01-2003, 12:53 PM
Kevin Stewart's Avatar
I would just drop the tranny also, inside the car at the rear under the carpet is a plate (center tunnel), under it is a allen screw to take the shifter loose, the drive shafts, ground strap, speedo sensor, should be it, on a 915 tranny you have to take the clutch spring off to release the bearing, woops also for got you have to disconnect the clutch cable to take it out, really easier just to drop the tranny along with the engine, Kevin
Old 08-01-2003, 12:54 PM
Ha ha, you are a victim of the crazy notion of dropping the engine alone is an easier job. I would not be around when you are trying to put it back, wiggling the engine with a jack to line up with the tranny. That can kill people.
Push it back up, attach it to the tranny, and drop the whole thing together, then separate it on the floor.
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 08-01-2003, 12:59 PM
rickeolis's Avatar
Porsche Crest Change of avatar-
4 votes to drop it with the tranny, plus my vote from a previous post-makes 5...
Good luck on this, one thing I found is that even though the bolts were off between the engine and tranny I still had to use a pry bar to seperate the two. TTYL-
-Rick-
-Rickeolis-
1986 Corvette
Old 08-01-2003, 03:24 PM
Forklift, jack, lift, motor, tranny, and you all under the car. Sounds crowded. Let us know what you decided and how it came out.
Old 08-01-2003, 03:28 PM
skinnerd's Avatar
I'd always drop the engine/trans as a unit as well. In the best of cases, it can be tough to get the engine remated to the trans when both are out of the car.
Drop 'em both. I used to do it with one floor jack at the balance point on the engine/trans assembly and the other on the car (I'd use a 4' length of 2x6 to spread the load). Once I dropped the engine/trans assembly as far as it would go with the one jack, I'd jack the car up with the other... high enough to pull the engine/trans out from underneath the car.
"Are you out of your Vulcan mind?"
Doug
2022 Carrera 4S, 1989 Delta Integrale, 1973 911T CIS
Old 08-01-2003, 03:33 PM
Jess's Avatar
A vote of dissent!
He's using a lift guys!
With access to a lift, absolutely drop the engine only. I'm going to guess that you haven't removed the clutch arm, helper spring, and cable. This is probably what's holding you up. Without these things removed, you cannot separate the engine and trans.
Sure, in my garage, laying on my back I drop them as a unit. When I am at my friend's shop and able to use a lift in conjunction with a floor jack, it's a no-brainer to drop just the engine unless you need the transmission out for maintainance on it as well.
Jess
Old 08-01-2003, 05:38 PM
Platinum Member
dad911's Avatar
Originally posted by Jess
A vote of dissent!
He's using a lift guys!....
I still agree with engine & trans together. No forklift required. Disconnect everything but trans & engine mount bolts. Lower car, and balance engine on jack or dolly. Remove final bolts, lower engine & raise car. No need to support trans up in the air.
The truth is that while those on the left - particularly the far left - claim to be tolerant and welcoming of diversity, in reality many are quite intolerant of anyone not embracing their radical views. - Charlie Kirk
Old 08-01-2003, 05:52 PM
8 to 1 in favor of dropping both. No contest,
Old 08-01-2003, 07:52 PM
Montana 911
k9handler's Avatar
well the tranny will drop today as well...going to make it easier to mate and install when I am done. I already disconnected the clutch cable, and backup light wires...so really all I can think of off the top of my head is the speedo cable and CV joints. How does the speedo cable come out?
H.D. Smith
2020 Yamaha YFZ450R
Old 08-01-2003, 08:09 PM
Montana 911
k9handler's Avatar
Oh...here is how she is at the moment, as you can see if I would have started off with dropping the tranny as well you would probably see the whole thing out of the car instead. So chalk this one up to a first time learning experience and press on.
otherwise, I feel ok with this project and should have it all back together today.
H.D. Smith
2020 Yamaha YFZ450R
Old 08-01-2003, 08:15 PM
If you have a mechanical speedo, it connects at nose cone of the transmission. I think a 17mm wrench will work.
Neil
'73 911S targa
Old 08-01-2003, 08:25 PM
Montana 911
k9handler's Avatar
oh...the whole unit comes out at the tranny.
H.D. Smith
2020 Yamaha YFZ450R
Old 08-01-2003, 08:27 PM
No, you just unscrew the connector that keeps the speedo cable mated to the speedo mechanism in the tranny.
Neil
'73 911S targa
Old 08-01-2003, 08:40 PM
Montana 911
k9handler's Avatar
that is what I meant, just didn't choose the best words to describe it.
It's the metal housing around the cable correct?
H.D. Smith
2020 Yamaha YFZ450R
Old 08-01-2003, 08:54 PM
Make sure you disconnect the shift linkage inside the car by the rear seat, Kevin
Old 08-01-2003, 10:20 PM
Montana 911
k9handler's Avatar
thanks Kevin, that was the first thing I did after I disconnected the battery.
H.D. Smith
2020 Yamaha YFZ450R
Old 08-01-2003, 10:22 PM
Montana 911
k9handler's Avatar
well after a long hot day the engine and tranny are back in the car, new clutch kit and clutch fork installed and I wish I new if it was all better!
After I got it all together and started it up for a quick second and then shut it down...as it's now leaking fuel. On the fuel return side at the pressure regulator (993) the brass fitting is stripped and will not seal up the line so it's leaking. The engine did start though, and everything else seems ok. I am going to get with Harald and see where he got the fitting from as one side is small (original hose and fitting from the 2.7 maybe) and the other side is larger for the 993. Any ideas?
H.D. Smith
2020 Yamaha YFZ450R
Old 08-02-2003, 08:38 AM
