driver
porcupine911's Avatar
Originally posted by HarryD
I must be slow, but I do not understand which way to slide my Sway Bars to loosen (create oversteer) the car.
To create oversteer with the sway bars, you would stiffen the rear and/or loosen the front.
To make the rear bar stiffer, you would make the C-D arm shorter (move the link from D towards C)
To make the front bar less stiff, you would make the A-B arm longer (move the link from B towards A)
I would recommend making only one change at a time, but I would tend to stiffen the rear first.
good luck.
-chris
- chris
Street: 1971 911E, 2007 GTI 2.0T, 2012 Cayenne Turbo, 2019 GTI TCR, 2022 Boxster 25 years
Circuit: 2020 Cayman GT4
Old 08-07-2003, 11:53 AM
HarryD's Avatar
good luck.
-chris
Thanks!
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 08-07-2003, 01:06 PM
