kellzey's Avatar
Thoughts on this carb jetting configuration
3.2L short stroke
9.8:1 CR 98mm P&Cs
Early SC Heads - single plug
Elgin S cams (similar to GE60s)
Electromotive HPX ignition
1 5/8" Headers and Sport Exhaust
Weber 46 IDA carbs
38mm Venturi
60 Idle jets
160 Main Jets
F7 Emulsion tubes
160 Air correction
How does the carb configuration sound?
Qarl
Old 08-05-2003, 09:51 PM
Early_S_Man's Avatar
Porsche Crest
Karl,
Those venturis are sized for a power peak at almost 6900 rpm ... sounds a bit high for GE-60 cams!
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 08-05-2003, 11:33 PM
kellzey's Avatar
The Elgin Modified S Cams (similar to GE60) should produce peak HP between 6800 and 6900 RPM. So shouldn't this be right?
Qarl
Old 08-06-2003, 05:33 AM
Randy Webb's Avatar
Is this a race engine? If not, the fundamental problem is the big carbs. Go with 40's for street use.
Old 08-06-2003, 10:31 AM
Porsche Crest
Karl,
Big problem with that chart is that it is, or seems to be, for a 2.0 engine [6800 rpm power peak for 'S' cams -- only valid for the '69 production engine] ...
The power peak with 'S' cams dropped to 6200 rpm for the RS 3.0 engine, and would drop to perhaps 6000 - 6100 rpm in a 3.2 engine! GE-60 and your Elgin grind would see similar drops in a 3.2.
I think you ought to go back to Elgin and ask what the power peak rpm should be for your setup. I think 35 mm venturis would be closer to matching your cams.
Warren Hall, Jr.
Old 08-06-2003, 10:46 AM
kellzey's Avatar
Both... Street car some... Racing yes...
Based on displacment and cams it's right on the cusp of 40s and 46s...
Plus, I already have the 46s.
Qarl
Old 08-06-2003, 10:47 AM
Randy Webb's Avatar
YOu may want to fax PMO.
Old 08-06-2003, 11:21 AM
kellzey's Avatar
Thanks everyone!
Qarl
Old 08-06-2003, 12:13 PM
