tholyoak's Avatar
3.6 conversion flywheel questions
Does anyone have a good pick of a 3.6 L conversion flywheel?
I am trying to diagnose a running issue and want to make sure i have the corect flywheel. If found this pic on the net of a 964 flywheel
This seems to agree with the drawing of a 964 flywheel I have in the service manual
You can see that the small hole for the dowel pin on the crank in both instances is approx. 9 teeth behind the gap in the teeth (in a clockwise direction).
However on my flywheel it appears that the pin is approx 9 teeth ahead of the gap in the teeth (gap at approx 11 o'clock) again in a clockwise direction.
I would like to see some pics of peoples conversion flywheels to make sure I am not barking up the wrong tree here. This is a '90 964 engine not a 993 motor if that matters.
Todd
1989 911 Targa
Old 08-13-2003, 06:58 PM
tholyoak,
I think you are looking at the illustration and photo backwards.
It illustrates the gap in the 60 tooth pattern in the same place as your photo of your flywheel.
I understand there are two sensor positions / brackets, you might have the wrong combination of bracket and sensor position if you are suspicious of a flywheel error?
Regards
Hayden
Old 08-13-2003, 08:36 PM
Bill Verburg's Avatar
Ahead or behind depends on which side of the flywheel you are looking at.
Bill Verburg
Old 08-13-2003, 08:51 PM
Both the top photo and the illustration are showing the crankshaft side of the flywheel.
Assume the view from the clutch side and they all match.
Regards
Hayden
Old 08-13-2003, 09:02 PM
tholyoak's Avatar
Stupid mistake on my part.
Todd
1989 911 Targa
Old 08-14-2003, 04:33 AM
