I have a 75 Carrera, I'm not quite sure how to describe my problem, but I'll do my best :-)
The sound sensor (part number 911 617 118 00) that makes a rather warbling noise (if the ignition is on, and the doors are open) is continually on on my Porsche after I start the engine. When the ignition is switched on, but the engine isn't running, the sensor doesn't make any noise, but as soon as the engine is ticking over the sensor noise kicks in - any thoughts? I was wondering if I could just take out the sensor and thus ignore it - but this seems a bit too cheap and risky for me! ![]() Last edited by UtahSaint; 08-16-2003 at 10:28 AM.. |
*Bump*
Help! - Sorry to be a pain, but there must be some 75-84 experts out there :-)
75 Carrera. Mello Yellow. |
mine never worked, i'm sure the PO disconnected it...
which one is yours? they both look nice
1975 911S Targa Silver Anniversary Edition |
yellow one is my pride and joy... when I'm not slumming it in the Expedition ;-)
I took mine out a few weks after I Bought mine, it drove me crazy!
If I remember right, the small buzzer is on a terminal block and just pulls out of the female spade connectors behind the dash. If I can remember correctly I did this from the trunk area and let it run while the box was buzzing, felt for it and pulled it out..... Viola! You might also access it from the speedometer hole once you pull it out. If you have a problem finding it post again, it's a little tight getting to it and pulling out. Rick
Rick '76 Carrera 3.0, track '77 3.2 targa, back home '95 993 C4 M030, SOLD PCA San Diego |
Not sure if it's in the same place as my '82, but look in the trunk behind the gas/oil level gauge. Mine was plugged in there. It was removed by a PO, but I have since installed a headlight reminder beeper in its place (after leaving my lights on for 14 hours and running the battery into the ground).
David Dryden '86 911 Coupe '05 BMW X5 4.4i |
Montana 911
it's in the dash, behind your guage on the far left.
H.D. Smith 2009 997.2 S 3.8 PDK 2019 Ford Ranger Lariat FX4 Baby Raptor 2019 Can Am Renegade 1000R XC 2020 Yamaha YFZ450R |
Thx guys - I found it via the hood - I pulled it out - no more noise :-)
I just hope it wasn't a noise sensor for any other important component...
Nah, it's just a warning relay letting you know the door's open with the key in the ignition...welcome to the mid-year cars! We of the '74-'77 cars have learned to deflect our share of abuse from the 'early' and the 'sc' crowd!
![]() Ryan
To the memory of Warren Hall (Early S Man), 1950 - 2008 www.friendsofwarren.com 1990 964 C4 Cabriolet (current) 1974 911 2.7 Coupe w/sunroof 9114102267 (sold) 1974 914 2.0 (sold) |
Thread Tools | |
Rate This Thread | |
