front - 309 x 32 rear are standard turbo
ok, thanks!
My side
My quick explaination: Rotors are drilled to lighten them, not to cool them. Yes in some conditions they are also there to give water, and foreign objects a place to go instead of getting stuck between the pad, and the rotor. .As in relation to cooling only!! >> a drilled rotor will run hotter and this is why. The drills remove inportant surface area needed in the transferance of friction in to heat. When the drilled space passes through the clamping caliper, the calipers force is constaint, and is producing a steady amount of friction/heat. The heat needs a place to go, but with the drill removing surface area, the same heat gets forced into a smaller surface area causing the areas directly around the holes to become a lot hotter then anywhere else on the rotor. This missing heatsink(rotor surface area) becomes a snowballing effect and the metal directly around the holes begins to expand at a rate faster then the metal not directly around the holes causing alot of pressure, this preasure is also converted into heat inside the rotor material. This is why a drilled rotor will crack around the drills, the metal gets so hot the whole rotor expands and contracts when cooling at direrant rates, thus causing the cracks. Remember As in relation to cooling only!! >> P.S. Joe, He has the same rotors you have.... and how did we get back on this thread, Its been dead for months... Dave |
It is time for a lil' quantification....
| All times are GMT -8. The time now is 07:56 AM. |
