Shawzy's Avatar
Question Best way to run wires to engine bay
Need some input...
Running some wires to my cruise servo from the front luggage boot to the engine bay - what is the best/easiest route?
If opportunity doesn't knock, make a door.
Old 08-17-2003, 08:07 PM
Cool Re: Best way to run wires to engine bay
I've done this for other things.
I like the pass side, next to the hump, up off the floor. if a few wires then I lay them flat and elec. tape a flat group. then some duct tape to keep them up off the floor. then gently shape them thru the rear cover and out to the tranny area.. zip ties inside the coupler area to keep the wires to the side. then a round bundle with plastic spiral or the slit wire conduit in the tranny area.. then into eng comp fuse panel area for a connector so I can drop the engine without having to deal with a direct wire feed.. I always use marine grade wires and solder everything...........Ron
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 08-17-2003, 09:34 PM
Shawzy's Avatar
OK - thanks - your engine drop tip is something I would have thought of after I had run everything so glad you mentioned it
Marine grade wires??
I assume these are more resiliant/robust than other wiring. Any special place to get such wire? I.e. I don't assume the Home Depot has this stuff...
Old 08-18-2003, 05:12 AM
Cool
the strands are tinned and the insulation is thicker. the long wire run, heat, and road salts etc makes me look for better wires that auto store stuff.. either stop at a marine supply store or one of the many mail order stores.. maybe try
www.freeportmarine.com
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 08-18-2003, 05:31 AM
