Jack Gresham's Avatar
Smile Unexpected pluses from the 930s steering wheel
I installed the 930S steering wheel and thought I would share some unexpected pro’s with you guys, esp. those thinking about the upgrade. More room, arms a little straighter when driving, more room around the knees, easier to get in and out of the car, (I am 6'2") better visibility, finger tips closer to turn signal lever, steering action seems a little quicker which I expected. Thanks for all the info on the install.
Jack
Old 08-19-2003, 12:44 PM
SCWDP- Shock and Awe Dept
surflvr911sc's Avatar
Congrats & enjoy! I love mine.
Ryan Williams, SCWDP
'81 911SC Targa 3.6
'81 911SC Coupe 3.2 #811
'64 VW Camper Bus, lil' Blue
Old 08-19-2003, 12:53 PM
Most pro drivers would tell you that your arms shouldn't be straighter when driving... Hands at 9 and 3, elbows at your side, and your butt firmly wedged as far back in the seat as you can get it -- that gives you the best road feel.
1968 911L
2004 Dodge Dakota SLT Plus
Old 08-19-2003, 12:55 PM
Irrationally exuberant
ChrisBennet's Avatar
I had one for a few weeks. I wrap my thumbs around the steering wheel at 9 & 3 and the "corner" there would attempt to pull my thumbs off. It was also a little too thick for me to get a good grip on (small hands). I reluctantly sold it. Beautiful wheel otherwise.
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 08-19-2003, 01:15 PM
With my thumbs like this, they would get stuck in the wheel.
Some may not likthe thumbs wrapped around but that's how I was instructed. I must admit, on in car video I find myself straying from this position some.
Link to article on 9 and 3 position.
-Chris
Old 08-19-2003, 01:25 PM
I usually try to keep my thumbs more vertical than that... a tip a rally driver gave me a few years back to prevent gripping the wheel too tightly and both losing road feel and increasing fatigue as a result.
1968 911L
Old 08-19-2003, 01:28 PM
I usually keep my thumbs out of the inside of the wheel. I might find out when I get to the track that it’s not right but it’s a habit carried over from 4x4 driving. If the wheel takes off on you it can break your thumbs. I don’t know if the same can happen if you abruptly exit the track too.
'81 911SC Targa 3.6
Old 08-19-2003, 01:36 PM
I just picked up Vic Elfords book and he says the same thing; Lay your thumbs along the wheel to avoid dislocating/breaking your thumbs.
gary
Old 08-19-2003, 01:55 PM
for the correct distance from the wheel my pca instructor recommended if you stick your arms straight out you should be able to bend your hands at your wrist over the steering wheel. this allows for the correct amount of elbow bend. thumbs on the outside or along top of wheel.
1980 911SC Targa 3.6L
Old 08-19-2003, 02:10 PM
Go Speedracer, go!
SpeedracerIndy's Avatar
All this talk about these lately makes me think I'm going to get one. They are very nice looking, and functional. One question though is why does pelican sell a "930s Style Steering Wheel Spacer"? Do you need this when installing the wheel, or is it an option?
1981 SC ROW Coupe
Old 08-19-2003, 02:24 PM
1fastredsc's Avatar
Send a message via AIM to 1fastredsc
I feel my best and most responsive with my hands in proper place (9and3), arms at slight bend (enough bend to where if i were to turn the wheel one turn over i could do so without letting go of my hand position), and knees slightly bent always. I also don't like laying back when driving, i usually am upright in my seat.
2007 Mazda 3 hatch
1972 Porsche 914 roller with plenty of holes to fix
Old 08-19-2003, 02:30 PM
jyl jyl is online now
jyl's Avatar
The spacer gives an extra 3/4" (roughly) of horizontal clearance between steering wheel rim and the dash pad above the instruments, where some feel the clearance is otherwise a bit tight.
If it is the eccentric spacer, it also moves the physical center of the wheel vertically up about the same amount, so it is off-axis with the rotation center, this gives more thigh room and I got used to the eccentric action right away. Don't know if you need the vertical room, depends on seat, thigh, etc.
Old 08-19-2003, 08:18 PM
I just installed the spacer after having the wheel on for about a year. I did it to give myself a little more leg room (I am 6'2") by allowing me to move the seat back one click and up just a touch. The eccentric is a bit odd but not really noticable.
gary
Old 08-20-2003, 09:52 AM
Administrator
Jack Olsen's Avatar
The spacer also lets you see your gauges.
Old 08-20-2003, 10:48 AM
Note also that the stock wheel is positioned eccentrically...surprise!
---Wil Ferch
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 08-20-2003, 11:02 AM
MN
Sarah's Avatar
We like ours too. The grip is a little bigger...but that has been ok.
87 930 Blk/Blk
Old 08-20-2003, 11:03 AM
