SCWDP- Shock and Awe Dept
surflvr911sc's Avatar
3.6 SC conversion preparation question (tearing stuff out)
I’m gutting the CIS wiring, which is mostly just the O2 sensor wiring now that the engine is gone. There is a small two wire harness (red & red/white) that runs from the O2 harness to the front of the car. I think that it’s coming off of the O2 sensor control relay and going to the fuse box and fuel pump relay (?). I’m not 100% b/c I didn’t want to destroy the harness insulation.
Can anyone confirm either where they go so I can disconnect them or that they are no factor so I can dike them off. TIA
Ryan Williams, SCWDP
'81 911SC Targa 3.6
'81 911SC Coupe 3.2 #811
'64 VW Camper Bus, lil' Blue
Old 08-26-2003, 07:22 PM
Kevin Stewart's Avatar
the new harness should have it on it, you can always do a search 3.6 conversion 1-2-3-4 etc, Kevin
Old 08-26-2003, 07:56 PM
Have what on it? I'm just talking about get the O2 sensor wiring from the 3.0 out of there.
'81 911SC Targa 3.6
Old 08-26-2003, 08:24 PM
Try again this morning.
I’m thinking about diking them. The small harness looks way too much of a PITA to try and chase it under the dash and through to the luggage compartment. I don’t want to have to take the whole car apart during this project.
Suggestions?
'81 911SC Targa 3.6
Old 08-27-2003, 07:43 AM
tholyoak's Avatar
When I pulled the 3.0L I removed that harness, it goes off and into the luggage compartment near the pedal box if I remember correctly. One wire went to the fuse panel and the other to a spade connector near the fuse panel.
Todd
1989 911 Targa
Old 08-27-2003, 08:12 AM
Thanks for the confirmation Todd. I’ll try to trace it through there before I grab the dikes.
This is starting to look like a good time to replace all the carpet. Will the ‘while your in there’s” ever end?
'81 911SC Targa 3.6
Old 08-27-2003, 08:29 AM
Heck, I’m only 5 not 71!
targa80's Avatar
Ryan:
This is from the Work shop wiring diagrams for the 81SC OXY control wiring. On the schematic there are 2 red wires and one red/wht wire.
first red wire starts at contact 30 of Oxy sensor relay and goes to fuse 18 (5A) a blk wire from the clock is also connected to the same terminal on the fuse.
Second red wire Starts at the OXY test connector and goes to fuse 22 (25A) there is also a red/blk wire attached to the same terminal on the fuse.
Red/Wht wire starts at terminal 86 on OXYsense relay and connects to a harness connector from there it goes to terminal 30 of the fuel pump relay. A blk wire is also connected to terminal 30 of the relay.
I could not find any other wires of that color combination in the diagrams for the OxY sensor circuits. Is it possible that this connector with the 2 wires is for some other use and not the O2 sensor circuits.
Pat Henry
Targa80
1980SC Targa (Mocha Brown)
Old 08-27-2003, 09:11 AM
I'm using the Bentleys but so far it lining up w/ what I'm seeing. I'll try to go through it a bit.
There are only two wires I'm concerned w/ here (red, red/white) b/c they are the only two that I haven't positively disconnected. I'm pretty sure that they are coming off of the OXS Relay.
Yes, I think that is the correct red one that's running to the front of the car.
This wire actually comes off the test connector and goes to the fuse (22) in the engine compartment. Funny, it took me a while to figure out why the diagram said it was fuse 22 but I only had 21 fuses in the panel, Duh.
Red/Wht wire starts at terminal 86 on OXY sense relay and connects to a harness connector from there it goes to terminal 30 of the fuel pump relay. A blk wire is also connected to terminal 30 of the relay.
Yep, that's the second one that's running to the front.
I could not find any other wires of that color combination in the diagrams for the OxY sensor circuits. Is it possible that this connector with the 2 wires is for some other use and not the O2 sensor circuits. [/B]
Bad explanation on my part. They are coming out the big wiring harness and I wasn't positive that it was the same wires as the ones on the OXS relay connector. I'm pretty sure you've confirmed what I was thinking.
They're out of there tonight, Thanks!
'81 911SC Targa 3.6
Old 08-27-2003, 09:43 AM
