Mikkel
Guest
Posts: n/a
Show me 911s with 8 & 9 x16 Fuchs!
I know this has probably been requested before, but I haven't found anything using the search function.
If you have a picture of a 911 with 8x16 Fuchs at the front and 9x16 at the rear please post it here.
Yes I'm considering replacing my Cup1 replicas, but don't get too excited - I'm still *considering*. BTW if anyone happens to know what offsets are preferred with 8s & 9s please mention it.
Old 08-30-2003, 06:21 AM
ttweed's Avatar
here's two of my '73- one at Ca. Speedway running the fully polished Fuchs 8 & 9s, and one at Qualcomm Stadium running modular 8 & 9s w/ black centers made up from 6 x 16" Fuchs and BBS barrels.
Offsets are 23mm on the 8x16" 944T Fuchs and 15mm on the 9x16s.
TT
Tom Tweed
Early S Registry #257
R Gruppe #232
Rennlist Founding Member #990416-1164
Driving Porsches since 1964
Old 08-30-2003, 07:37 AM
Mikkel. I love this request!!
Old 08-30-2003, 07:38 AM
Mikkel
Guest
Posts: n/a
If you can't beat them, join them
Joking aside. I'm very interested in getting forged quality wheels.
TTweed, thanks. Those offsets were also the ones that I could remember. I just wasn't sure.
89911, I love picture 2. Great picture! I guess your car is a low as mine? It really helps make the car look mean.
Old 08-30-2003, 08:17 AM
Mikkel
Guest
Posts: n/a
What about these? They are forged and build from scratch without using donor parts.
Probably very expensive
BTW if anyone has more pics please keep'em coming.
Old 08-30-2003, 08:20 AM
Todd Simpson's Avatar
Same set up as Tom's first picture.
Here's a funny one where you can't see the depth of the 9's at all.
Old 08-30-2003, 09:09 AM
Mark Wilson
Guest
Posts: n/a
Old 08-30-2003, 09:24 AM
Mark, those 9s look like they have the same depth as my 8s.
On 9's, is the additional inch all towards the inside?
Old 08-30-2003, 09:28 AM
Sonic dB's Avatar
7s and 9s. Beefy look. Wheels make all the difference in a lot of way. Highly recommended upgrade.
Old 08-30-2003, 10:02 AM
Mark Wilson
Guest
Posts: n/a
Brian,
Here is a neat chart one of the board members did showing the differences. Sorry, I don't remember who it was , so can't give due credit.
Old 08-30-2003, 10:05 AM
Mikkel
Guest
Posts: n/a
Very nice all. Thanks. Very nice chart also.
Old 08-30-2003, 12:49 PM
D Hanson's Avatar
The red convertible is looking good. Are those 15 inch or 16 inch.
90 C2 Cab Ruf Red/Blk
03 Caynne S L.Blue/Grey
03 996 TT Blk/Blk
04 996 Atlas Grey/Blk
Old 08-30-2003, 01:15 PM
Bill Verburg's Avatar
Be careful how that chart is used, the data is based on bead width not actual width, all the back and front space #S will need to be adjusted to correctly position things.
It is great for comparison though.
Bill Verburg
Old 08-30-2003, 03:51 PM
MBruns for President
JeremyD's Avatar
951 8x16's and 9 x 16's
Old 08-30-2003, 07:30 PM
Mikkel
Guest
Posts: n/a
With 8x16 at the front I would run 225/50x16. Has anyone had problems with that?
I'm running slight negative camber with the Cup1s to avoid rubbing. My guess is that I have to continue with that if I go for 8 & 9x16 Fuchs? I haven't rolled my fenders because I prefer not to do so.
Old 08-31-2003, 12:40 AM
teardrop's Avatar
Bill, It was me who created the chart. I did it for the exact reason you state which was just to compare sizes, specifically 8's and 9's. It showed me that visually, from a 'stickyoutness' point of view, there isn't much difference between 8's and 9's. I still got 9's for the rear though
I am interested in your comments though. Is there anything else I could add to it. If you've posted before explaining about this (I've a feeling you have) then can you post a link here.
Cheers
Andy Jones
Old 08-31-2003, 04:39 AM
Mark Wilson
Guest
Posts: n/a
Andy,
Your chart is a great tool. Thanks for doing it up.
Mark
Old 08-31-2003, 05:32 AM
KTL KTL is offline
Schleprock
KTL's Avatar
Nick Moss (nick-moss) has a nice page about the difference between the 16x8 Fuchs and 16x9 Fuchs that would be used for the rear:
http://www.nicholas-moss.co.uk/porsche/carrera/html/rims.html
On his page you'll see that the faces of the 8 & 9 are just the same. So where the 9 is wider than the 8 is in the countersunk lug holes (pushes the wheel outboard if hub depths are same) and added the added width on the inboard side of the rim barrel
Also, the 911 16x7 (+23.3 mm o/s) and the 951/944 Turbo 16x8 (+23.3mm o/s) also look the same on the face side. Once again this is due to the countersunk lug holes on the 8 and the added width on the inboard side of the rim barrel.
I recall some people having a bit of trouble with the 225/50 on the 951 +23.3 o/s Fuchs 8. So a 225/45 may be a better choice. I believe that's what Mike (89911) did. I think fender rolling/shaving and extra camber is a must with the 951 +23.3 o/s 16x8?
Kevin L
'86 Carrera "Larry"
Old 08-31-2003, 09:47 AM
Mikkel
Guest
Posts: n/a
I'm a little confused now.
Will a 9 inch Fuchs not stand out further than an 8 inch due to the different offset?
Old 08-31-2003, 10:10 AM
JeremyD's Avatar
yes mine required a little rolling with the 16 x 8 fronts. I have the 225/50 - it was tight - especially on the driver's side - I think 89911 went with a 255/45 - but he's lower than I am too.
I don't think the real difference is the look but rather how the tire sets up on the rim a 225 on a 7" typically has much more "balloon" where the profile of the tire and sidewall is much straighter on the 8". Also think the 8" has more room for bigger brakes - if you are so inclined...
Old 08-31-2003, 10:22 AM
