Czar of C.R.A.P.
dfink's Avatar
front spindle cap
Tring to adjust the front wheel bearing and can't seem to get the bearing cap to budge. Do they just push on like most other cars or do the screw on. I generally just use a Channel lock and wobble them off.
66 912 Coupe
84 Carrera Cab Hardtop HC3.4 Hyper Carrera
2005 Dodge Magnum 5.7 HEMI
Cabriolet Racing And Performance C.R.A.P. Gruppe #1
Put on some C.R.A.P. and drive....
Old 08-31-2003, 02:04 PM
Czar of C.R.A.P.
dfink's Avatar
Sorry just fond the post for the 2 1/8" muffler clamp. will give that a try.
66 912 Coupe
Old 08-31-2003, 02:11 PM
Formerly bb80sc
Vipergrün's Avatar
If that does not work, use a piece of 2x2 about 8" long. Get the edge of the 2x2 under the *lip* of the cap and angle it to the inside of the wheel well at about the 4:00 position. Use a hammer and tap on the 2x2. Rotate the rotor 180 degrees and repeat. I use this method all the time and works great. Is that clear??? Have fun!
Cheers
-Brad
2015 Cayman GTS
2015 4Runner Limited
Old 08-31-2003, 04:04 PM
Czar of C.R.A.P.
dfink's Avatar
The muffler clamp didn't work at all. Finally went and got a very large set of channel locks. I had lost mine someplace. This worked to rock the cover off. Had to get a good grip then smack the top the channel lock with a hammer. Now that they are broke loose the 2X2 method would probably work great and wouldn't damage the cap. Thanks for the answer. The search works OK and I did find some suggestions but you can spend all day reading through threads till you find what you want.
66 912 Coupe
Old 08-31-2003, 04:14 PM
