Lightbulb Wiring problem
I have recently had the misfortion of unpluginh the guage wires and as a result I can't determin what is the VDO wire and color to reconnect it. I also would kike to know would this cause alternator from charging. thanks Rusty.
Old 09-07-2003, 01:49 PM
Sports Purpose 911 Driver
mjshira's Avatar
Rusty
I wish I could tell you which wires so to which gauge, etc. However, I can tell you that even if these wires are not connected your alternator should still be charging the battery. You may want to buy the correct book for your car (see this site for your year, etc.) I did and it helped me as a reference. Toward the back you'll find wiring diagrams which can help you get a start on putting the wires back to the correct positions. Good luck! James
James Shira R Gruppe # 271
1972 911 Coupe 3.8 RS ‘nbr two’
1972 911 Coupe 3.2 TwinPlug MFI 'Tangerina-Jolie'
1955 356 Pre A Coupe ‘old red’
1956 356A Emory speedster build in progress
Old 09-07-2003, 02:23 PM
Cool Re: Wiring problem
the alternator gauge lite is part of the charging circuit.. in my car it's the "G" red light
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 09-07-2003, 02:27 PM
Early_S_Man's Avatar
Porsche Crest
Rusty,
You already have the answer, and color schematic to your 'VDO Poll' question ... Blue D+/61 wire from relay/regulator/CDI panel ...
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 09-07-2003, 03:59 PM
Thanks I tried that but no luck. I did get some other things going but I guess it's just time to empty the pocket book and tank it in. The last time i did this it cost 365.00 and made it home and it was time to start pulling the guages out as fast as i could to prevent a fir. Thanks again.. Rusty
Old 09-07-2003, 10:06 PM
McDaniel's Avatar
Not Charging
If the D1, (blue) wire is not connected at the gauge the alternator will not charge. I know from first hand experience, had a broken wire at the VR and had a H**L of a time tracking it down.
Impotence...Nature's way of saying "No hard feelings."
McDaniel
1974 911 Targa
1995 Toyota Avalon
2004 Toyota Tundra Extended Cab
Old 09-08-2003, 02:34 AM
