Dropping engine from 84 911
I have a friend with an '84 911 who I promised to help drop the engine. I have done this a couple of times with my '70 911 but I remove the rear valance plate behind the muffler to roll the engine out from under the car. My question is, with the different rear bumper how high do we have to raise the 84 911 to get the engine out.
Thanks,
Allan Broadribb '70-911E, 2.2l with Webers http://www.cheaterswayside.com/uploads/Mvc-002s355.jpg |
Same will do. remove bumper and rear valence will help tremendously
Porsche 2005 GT3, 2006 997S with bore-scoring Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS Disposable Car: BMW 530xiT, 2008 Mini Cooper S Two-wheel art: Ducati 907IE, Ducati 851 |
If it is anything like an SC, the answer is either "Pretty Damn High" or "Insanely High"!
Seriously, the first time I removed the engine, I tried jacking it up to the required height, and it was stunningly high to my eyes. I just pull the bumper to avoid that. Even with the bumper removed, it still has to be pretty high. |
Eugene (Formerly) at Pelican Parts Pelican's E-Commerce Guy, 2003-2011 2001 330i Sport 1983 911SC Coupe (sold) Last edited by Eugene at Pelican Parts; 09-10-2003 at 03:59 PM.. |
The top of your jackstands will need to be at least 21.5" above the floor, where they support the car at the torsion bar covers. That's with the valence removed, bumper installed. I cut some 9"x9" boards, stacked to 5" high on each side, under the jackstands (3-ton, standard size). Works great, lasts a long time!
'85 Carrera Coupe, White Gold Metallic - 8" rear Fuchs, Fittipaldi steering wheel, Weltmeister short shift, Turbo tie rods. "If you can make black marks on a straight from the time you turn out of a corner until the braking point of the next turn, then you have enough horsepower." - Mark Donohue |
