jakermc's Avatar
Non-slip surface for driver side floor?
I just recarpeted the car with an RS kit, but since my 911 is dedicated to the track, I 'd like an alternative to floor mats for the front of the car. Ideally it would be some sort of paint or stick on non-slip surface I would put down on the floor instead of using carpet. Something black would be preferred to match the carpet in the rear.
Any ideas?
1983 911 3.6L - NASA GTS-3 class
1998 Boxster - PCA SpecBoxster, NASA GTS-2
2003 996X51 - NASA GTS-4, PCA GTB
2003 996 Carrera 2 Coupe
2003 Ferrari 575M
Old 09-11-2003, 07:44 AM
n8marx's Avatar
How about the spray-in bedliner stuff? I had one in my pick-up and it was very non-slip. You can even buy it in cans at the auto parts store. Use a roller to roll it on where ever you want it. It may be difficult to remove if you ever decide to do that.
Nate
Gone: '86 Carrera coupe
Current: a $75 BMW 320i
Old 09-11-2003, 08:29 AM
I use the material you can purchase for floor tread edges. It comes in several sizes and you can cut it to fit where you need it. I use in directly infront of my pedals to keep my heel in place, epecially if it is a wet day. Usually can fint at a Sears hardware or Home Depot.
Old 09-11-2003, 08:36 AM
Go to AircraftSpruceandspecialty.com (?)...and look for Ray Allen's "Wing walk"...a rubberized, adhesive-backed textured surface that comes in sheet sizes. Black. Also good for duping Turbo spats for the rear fender area..
---Wil Ferch
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 09-11-2003, 08:39 AM
You can get non-slip additive from West Marine or other boating stores. Add this to paint and apply. Or you can go even cheaper, add sand to paint.
Old 09-11-2003, 08:42 AM
How about the stuff that they stick on skate boards. Kind of like adhesive backed black sand paper.
Old 09-11-2003, 08:52 AM
Original Owner
tsuter's Avatar
Try these puppies:
http://www.weathertech.com/store/vehsearch.asp?make_id=43&year_no=1978&veh_id=567&veh_opt_choice_id=0&item_group_id=33
tsuter
78 911SC Turbo Targa
Thaaaats Right!!
Old 09-11-2003, 09:02 AM
Certified Pre-Owned
BGCarrera32's Avatar
Do the whole floor in velcro...next do the bottom of your shoes...
'84 Carrera Coupe
Old 09-11-2003, 04:36 PM
Insert Tag Line HERE.....
rattlsnak's Avatar
Im spraying my floor with Line-X. I have used a product from 3M before, in a spray can. Some type of undercoating, it worked great. It took about 3 cans to do the whole floor.
Marc
Old 09-11-2003, 06:58 PM
jakermc's Avatar
will the bedliner add much weight? It looks a little heavy for a track car.
2003 Ferrari 575M
Old 09-12-2003, 03:48 PM
How about the rubberized undercoating you can get at any auto parts store. That should be light if you spray a few thin coats and should hold up well. Just make sure you mask off the other areas before spraying.
Bill
Old 09-12-2003, 03:59 PM
rattlsnak's Avatar
Enough Line-X to cover the inside of a car, or bedliner, is @18 lbs. Im not that critical on weight. I would rather have the protection.
Marc
Old 09-12-2003, 06:01 PM
I made some floor covers out of sheets of thin rubber. Works very well.
I like them I drive them
Old 09-15-2003, 08:51 AM
