Irrationally exuberant
Of turbo bodies and G50's..
Hi,
I'm always answering questions, now it's my turn to ask some. ![]() Does the turbo body have a bigger transmission tunnel and is it big enough for a G50? Was the '77 930 transmission shorter than say an '86 930 transmission? thanks, Chris
'80 911 Nogaro blue Phoenix! '07 BMW 328i 245K miles! http://members.rennlist.org/messinwith911s/ |
Chris,
From what I understand, the '86 930 tranny is longer than the 7X tranny. I have purchased an 86 930 going into a 72 and was advised that I need to cut the bellhousing for fitting. I do not have info about the tunnel. The info above is as of Friday of last week. |
Thanks "cab".
-Chris
930 bodies between 75' and 78' were same as SC bodies (apart from fenders).
Starting from 78' model, some genius at Porsche decided that rubber-damped "exploding" clutch is just what we need. This forced the factory to lenghten 930 transmission bell-housing around the clutch and move engine further back...so all 930 bodies are longer in the back than coresponding SC/Carrera ones. What this "update" cost in retooling and exploding rubber clutches is still to be found out. Anyway, it means that 930 <78 and all SC and Carreras share the same body, but all 77> 930 are somewhat longer in the back. That being said, i don't know if OEM "turbo look" cars are of pre- or post-78 type. Also, as far as i know, G50 installation will require cutting out a piece of torsion-tube (=coilovers) to acomodate longer front "overhang" of G50. I posted some info and pictures in this thread, check it out: 78 930 powertrain swap to 77 930 body? Cheers! /Goran
Thank you for your time, |
Thank Goran.
-Chris
Goran:
To be clear..when you say "bodies" are longer, you obviously mean transmision bodies....the car bodies are the same length in all cases.... no ? ---Wil Ferch
Wil Ferch 85 Carrera ( gone, but not forgotten ) |
To better illustrate this, i uploaded cutouts of <78' and 78'> 930 body here: 78 =>: < 78: ![]() Check out distance between rear engine mounts... (I've become unvolontary expert in this field beacuse we had to do extensive research before our conversion-project...)
Thank you for your time, Last edited by beepbeep; 09-15-2003 at 10:20 AM.. |
Your drawing (only) shows that the inside of the engine compartment is larger. Any chance the true length of the car is the same i.e. measured to say the lid latch or outside of the tub (underneath the rear bumper)?
-Chris
![]() I just know that engine sits further back...it would be easy to check by comparing article #'s for sheetmetal flares for pre and post 78 930's. If they are different then body itself is longer...or i could superimpose drawings to each other.
I too have a question was the 88-89 the Only ones with the G-50 ? Can someone post the designation on years for the 930 cars
G-50 what years 915 G-50-50 G-50-52 Thanks........
10.76@139-1/4 mile 0-1 mile 193MPH I Love to Shine Cars
915 '72-86 G50 '87-89 Carrera G50 '89 930
AFAIK, only 89' 930 had G50 , then 964 came.
930 never had 915 tranny's...it had short 930 tranny (930/30 i think) 75-77, then long one 78-88 (930/34)
Super Jenius
Goran -
A Porsche guy pointed out to me how the mounting points are different on side-by-side specimens. The aft-most mount is located about an inch further back in the body, but the bodies are the same. Lift the tail of a 78+ 930 and look for the rear mounting bolt -- it's almost back under the lip of the engine bay. Now open any non 78+930 (911) and you'll see the rear mount is about an inch further forward. You'd never notice it until someone points it out (well, I'd never have noticed it). JP
2003 SuperCharged Frontier ../.. 1979 930 ../.. 1989 BMW 325iX ../.. 1988 BMW M5 ../.. 1973 BMW 2002 ../..1969 Alfa Boattail Spyder ../.. 1961 Morris Mini Cooper ../..2002 Aprilia RSV Mille ../.. 1985 Moto Guzzi LMIII cafe ../.. 2005 Kawasaki Brute Force 750 |
Administrator
Worse f/r weight distribution.
What a crazy decision to make for the top-of-the-line model.
Jack Olsen 1972 911 My new video about my garage. • A video from German TV about my 911 |
But didn't the factory also use longer trailing arms to push back the wheelbase a bit? I thought this was supposed to negate the weight distribution issue. (At least the issue of moving the engine rearward. It's still obviously a heavier engine).
993 |
Super Jenius
Colin - I don't know if there are longer trailing arms, honestly. It's still more weight aft in an already tailheavy car.
If I'd had the stomach for another project, I'd have bought a 77 and used its transmission w/ my 78 motor, for the better f/r weight dist.
"Overpaid Slacker" had it right..
....the "internal" body ( if you wish to call it that) may be longer, but the outside sheet maetal stampings did not change, nor did the overall length of the external car. Rear rockers, flairs, etc...would otherwise all be different. --Wil Ferch PS-Chris...the 86 Carrera is RIP?? What ??
All 911 and 930 '76 - '87(last year I have hard data for)
Bill:
Thank you...as I thought ..... ---Wil
