Grounding engine?
1983 911SC
I measured 12-13 ohms between the engine and the body chasis while the engine was running. Is there a need to ground between engine and chasis? I have replace the transimission grounding recently. The reason I want to ground is sometimes I think I hear what sounds like electric arc cracking.
Doug
Old 09-16-2003, 07:39 PM
Cool
I don't know about your arcing.. But I take the engine/tranny ground maybe perhaps to seriously. I added an additional ground strap from the starter bolt to the engine mount bolts.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 09-16-2003, 11:34 PM
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 09-16-2003, 11:35 PM
I had a similar problem. Only my car wouldnt run. Check your coil wire, then check your distributo wire..the one running form the side of the distributor to the CDI. Also, take a good look at it running in the pitch black. My coil was archin out too becasue of the bad coil wire.
ohhh yea!
Old 09-17-2003, 12:51 AM
I had a similar problem. Only my car wouldn't run. Check your coil wire, then check your distributor wire..the one running form the side of the distributor to the CDI. Also, take a good look at it running in the pitch black. My coil was arching out too becasue of the bad coil wire.
ohhh yea!
Old 09-17-2003, 12:52 AM
I added one also: Chassis to the starter bolt!
Old 09-17-2003, 03:50 AM
