Location: 24 miles from Lime Rock Park. 1 light, 8 Horse Farms, 114 Turns
DE Brake issues
I have questions on two brake issues. I have an 86 Carrara, (stock with Porterfield Pads). I am mid pack in intermediate run groups.
1) I often get a front brake vibration after the brakes get warmed up, but it seems to go away later as the brakes get hotter.
2) My rear pads wear faster than my fronts.
I have heard a couple of theories for each of these situations, and I am prepping for a 3 day event in 2 weeks. What are some suggestions?
Alan
Old 09-20-2003, 05:52 AM
ttweed's Avatar
Re: DE Brake issues
For #1, I would guess you are getting some kind of pad deposit on the rotors which is causing the vibration and that it somehow burns or melts off at higher temps? I have not used Porterfield pads, though, so I don't really know about their characteristics.
I have no idea about #2, as my front pads always wear faster due to the higher loads on them, but I have never owned a Carrera, and maybe the bias setup is different than on the early cars.
My suggestion is to check your pad depth after every session and bring an extra set of pads to the track which have already been bedded in so that you can swap them out if necessary. Otherwise, don't worry and have fun.
TT
Tom Tweed
Early S Registry #257
R Gruppe #232
Rennlist Founding Member #990416-1164
Driving Porsches since 1964
Old 09-20-2003, 06:13 AM
Irrationally exuberant
ChrisBennet's Avatar
With stock brakes and Pagid Orange pads I think my rear pads wore faster than my fronts until I got brake cooling ducts for the front. After that it went to 17 days front/14 days rear.
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 09-20-2003, 06:59 AM
Administrator
Jack Olsen's Avatar
Rotors could be warped. As their temp changes, the specific shape of the 'potato chip' effect will change. I don't know if that would contribute to reduced wear, though.
Old 09-20-2003, 10:52 AM
mm86911's Avatar
Run cooling ducts front and rear and then evaluate.
Mike - PBG, FL
'14 958 Cayenne GTS
'05 997 C2 - SOLD
'79 911 SC Widebody PCA, NASA, PBOC - SOLD
2004 NASA-SE GTS4 Champ, 2005 + 2007 NASA-SE GTS3
Old 09-20-2003, 02:22 PM
Bill Verburg's Avatar
Your rears will wear faster than the fronts if you remain in the regime of under 33bar of line pressure. The factory did that on purpose.
At a track you should be braking hard and be above the 33bar knee most of the time.
I suspect that most of the wear is from street driving and perhaps you may need to modify your braking style to use shorter but more aggressive braking zones.
Another possibility is to use an adjustable p/v w/ more aggressive knee settings.
A third and far more expensive option is an adjustable dual master cylinder set up as described in this thread The owner didn't identify what chassis he has but in retrospect it is likely that it is a Carrera as these models have by far the worst stock bias.
Bill Verburg
Old 09-20-2003, 02:46 PM
