Vintage911Racer's Avatar
Send a message via AIM to Vintage911Racer
Engine Oil Cooler Help
Does anyone know if the engine oil cooler can be removed from the engine with out having to drop the motor?
I know the Passenger side headers need to come off, and the fiberglass air flow piece that is on top of the engine shroud needs to come off as well.
Anybody have an answer or maybe shed some light on this for me? And is it a easy task once it is out?
Thanks in Advance!!!
Oh yeah, the car is a 1967 911S.
Mark Scott
Vintage 911 Racer
1967 911S 2.4L ROCKET
Powered by Faragallah!
www.scottassociatesracing.com
Old 09-19-2003, 01:16 PM
help
Mark Scott
Vintage 911 Racer
Old 09-19-2003, 01:46 PM
Irrationally exuberant
ChrisBennet's Avatar
I don't see why the headers would be in the way. I mean I don't think stock ones would be in the way.
Do all 911's have the removeable piece over the oil cooler or was that a later (than '67) developement?
If you've got leaks in that area, check the case itself behind the oil cooler. I've seen the case leak at the little "window" behind the cooler. I'm not saying it is likely, just be aware that it does happen.
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 09-19-2003, 02:31 PM
Chris,
These are after market racing headers. I do not think the cooler could make it past the header if I left it on. yes, the removeable peice was added to aid in the cooling.
I have heard that the O-rings at the attachment from the cooler to the case can go bad and cause the leaking I might have. Have you heard of this. Are they easy to replace. And what do you think about the Performance Products aftermarket Engine Oil Cooler they sell for $399.00? I would hate to spend $1300 for a factory cooler if I have to replace it.
What "little window" are you talking about.
Mark Scott
Vintage 911 Racer
Old 09-19-2003, 02:56 PM
The little slot above the lowest hole is the "window" I'm talking about.
Leaks in that area can come from above (oil pressure switch, thermostat O-ring), cylinder base gasket or if you are unlucky, from a leak in the case itself right behind the oil cooler. This motor had leaks from all four places.
-Chris
Old 09-19-2003, 04:06 PM
Chuck Moreland's Avatar
You can pull the cooler without pulling the engine. You will need to drop the motor 6 inches or so to get enough working room.
It's not fun, but it's doable.
Chuck Moreland - elephantracing.com - vonnen.com
Old 09-19-2003, 04:48 PM
HawgRyder's Avatar
Send a message via ICQ to HawgRyder
That "window" looks like a hole in the engine case!!
Bob
Bob Hutson
Old 09-19-2003, 07:13 PM
I can't find a good picture of that location. The case has a big hole (1" diameter or so) that drills down from the top of the case almost to the bottom. The case has a couple of slots/windows that I suppose correspond to the bottom of that hole. Maybe to let the chips out during manufacture? One window is behind the oil cooler, the other window is behind #6 cylinder (I think). The big hole has a pressed-in tube that seals off the "windows" from the outside. After a while, this press fit doesn't seal that well I guess.
-Chris
Old 09-19-2003, 08:01 PM
47silver's Avatar
vintage
do a search there are a couple of threads about partial engine drops.
gary
1975 911S Targa
Silver Anniversary Edition
Old 09-19-2003, 08:33 PM
Thanks for the help guys!! I will look into it.
Mark Scott
Vintage 911 Racer
Old 09-22-2003, 07:51 AM
SteveM911's Avatar
Vintage
You will need to do a partial engine drop and take the rear wheel off to
help access, its a bit of a fiddle manuvering the cooler out, the seals are easy to replace once the cooler is off, if you can it would be worth getting the cooler pressure tested for leaks. I checked mine when I had it off and it had a small pin hole which was causing the leak, not the seals.
Steve (Strosek34)
86 - Carrera 3.4 LWT
www.impactbumpers.com
Old 09-22-2003, 08:19 AM
Thanks Steve. I will have that done as well.
Mark Scott
Vintage 911 Racer
Old 09-22-2003, 09:11 AM
