LSD experiences
Now before you hippies start telling tales about the 60's read the questions...
My new 915 gbox with Quaife torque sensing LSD is nearly ready to go in my 2.7RS replica track car. 1. My understanding of the Quaife set up is it will lock under acc'n and release under braking - is this correct or over simplifying things? 2. Would you alter your driving style in any way when using an LSD? 3. Would you alter your car set up in any way (sway bar settings/ alignment etc)? 4. Tips? Cheers - Ryan |
1)It's definitely overly simplistic, but not untrue. I believe that it only locks up as necessary ...
2)Yeah, I'd use more right foot. 3)Yes, but only as necessary. Drive it without changes to see how the new LSD affects the car's overall tendencies ... then make adjustments as needed. 4)Don't take the brown acid ... "It's not poisoned, just poorly manufactured." |
Senior Member
Just try to be in a relaxed state of mind when you do it, and in a location free of sirens and stuff. It can really enhance your performance.
Oh, and you'll like the Quaife too.
Man of Carbon Fiber (stronger than steel) Mocha 1978 911SC. "Coco" |
I've had mine for about 6 months. During normal driving (street), you won't know it's there. I only notice a substantial difference around turn 7 at Road Atlanta and during Auto-x. I expect to notice an improvement at Barber next month coming out of the hairpin and corkscrew. Anywhere you're on hard throttle coming out of a tight corner, you'll appreciate it. I do not notice any appreciable increase in understeer.
Mike 89 Carrera 3.6 V-ram #94 Livin' for Targa time! Want to make God laugh? Tell him your plans! |
Thanks guys - I'll report back when its fitted and given a run.
Cheers - Ryan
Cheers, Ryan 1969 911E (historic racer) 911ST replica (tarmac rally) |
Did you do the LSD installation yourself? I was previously given 'thread response' instructions but would appreciate if there is actually a manual/written documentation I could acquire.
Thanks! |
Cab - nope, I bought a gbox with a LSD in it, pulled it apart, then gave it to my mech and said "pls put it back together with whatever new bits it needs" It is soon to be swapped for my existing gbox
Cool thing was I assumed it was a ZF (and paid accordingly) but ended up with a Quaife!
Tune in...turn on...er, forget the last part.
Given the choice of keeping my orignal ZF or installing a Quaife, no price diff. to me? I kept the ZF, but that's just me...
"Now, to put a water-cooled engine in the rear and to have a radiator in the front, that's not very intelligent." -Ferry Porsche (PANO, Oct. '73) (I, Paul D. have loved this quote since 1973. It will remain as long as I post here.) Last edited by pwd72s; 09-29-2003 at 08:03 PM.. |
Once had a lawnmower talk to me. Said my hand was doomed? Now that's LSD!
Troy 72' 911 T 97' Boxster 81' SC coupe / sold 76' slant nose 81' SC Targa / sold 77' s / sold 67' 912 / sold 89' 944 / sold 74' 914 / sold 71' 914 / sold |
FTY - A Quaife is not a Limited Slip Differential but rather a Torque Biasing Differential. Both terms are pretty accurate about describing their effects vis-a-vis each other. I agree with the descriptions given above, so I'm not going to repeat them.
John '69 911E "It's a poor craftsman who blames their tools" -- Unknown "Any suspension -- no matter how poorly designed -- can be made to work reasonably well if you just stop it from moving." -- Colin Chapman |
None of us can remember the 60's (or 70's and early 80's).
Thank you Mr. Leary.
78 911SC sunroof Coupe (SOLD) 97 328i Convertible |
Double Trouble
What? Huh? Had a picture on the wall play cello once. He was playing the overture from Tommy.
I used to be addicted to the hokey pokey..........but I turned myself around.. 75 914 1.8 2010 Cayenne base |
Agree, more understeer, you'll just use more gas to compensate. Also agree that the Quaife and their ilk are more suited to autocross than track use. Clutch type is better for a track than autocross.
My understanding is that clutch one is marginally better on trailing throttle and braking but it also wears with time and gradually loses it's diff-braking ability where Quaife unlocks on braking but doesn't have clutches that wear out. Now White Rabbit is probably the best if you can find one...
Thank you for your time, |
I agree with Mike above. I swapped out my open diff for a quaife at the same time as a dose of hp upgrade to the motor. I really notice it when stepping on the throttle out of a turn. It really dig's in now.
ZF type LSD's come in different flavors of lockup. The earlier ones only locked up under acceleration. The later ones lock up under acceleration and deacceleration to varying percentages. Depending on the Hp output of your car is how much lockup you want to use. For example, the 917's use a spool thus eliminating a diff. Now for a regular car that would be a waste since most cars don't have the Hp to take advantage of this. ZF's will decrease tire life but if used correctly will drastically reduce laptimes. The added advantage of locking under deacceleration gives the benefit of more stable trail braking in a 911 which in turn allows you to go into a corner deeper. In many ways a Diff should be considered part of the suspension and will need to be considered in the setup.
Cheers, James
You will never know the feeling of a driver when winning a race. The helmet hides feelings that cannot be understood. Ayrton Senna 1993 964 RS |
While it's true that the ZF clutchs do wear, the Quaifes have their own reliability issues. Carrol Smith has advised agaist them for track cars in his Tuning series. Though I think that they are fine even desireable for A/X and street use.
I would go with the ZF because I am a fan of OE ... Quaife might be better, but I personally don't care. JUST MY IDIOTIC OPINION.
Also, the White Rabbit is highly overrated ... I am a BIG fan of Alien Juice (it's a modern thing, don't ask how I know) or Window Payne <-- a friend's mom had some left over. Also ... tune in, turn on, drop out.
Here is an excellent article addressing Porsche Limited Slip Diffs.
Limited Slip Article Cheers, James
