LSD experiences
Now before you hippies start telling tales about the 60's read the questions...
My new 915 gbox with Quaife torque sensing LSD is nearly ready to go in my 2.7RS replica track car.
1. My understanding of the Quaife set up is it will lock under acc'n and release under braking - is this correct or over simplifying things?
2. Would you alter your driving style in any way when using an LSD?
3. Would you alter your car set up in any way (sway bar settings/ alignment etc)?
4. Tips?
Cheers - Ryan
Old 09-29-2003, 02:59 PM
Mr9146's Avatar
1)It's definitely overly simplistic, but not untrue. I believe that it only locks up as necessary ...
2)Yeah, I'd use more right foot.
3)Yes, but only as necessary. Drive it without changes to see how the new LSD affects the car's overall tendencies ... then make adjustments as needed.
4)Don't take the brown acid ... "It's not poisoned, just poorly manufactured."
Old 09-29-2003, 03:16 PM
Bill Verburg's Avatar
Correct, but lock is too strong a word, limit the differential action is more like it. For the track you would also want to do this under braking, as a conventional clutch type ZF will. An 80/100 PMS trans can actually go to full lock under braking, this is good! The Quaife are better suited to A/X than to track use because they don't work on trailing throttle
Under power there will be more understeer, you will need to compensate.
See item 2 above the chassis can be set up to compensate for the understeer which is more pronounced at lower speeds.
Bill Verburg
Senior Member
Superman's Avatar
Just try to be in a relaxed state of mind when you do it, and in a location free of sirens and stuff. It can really enhance your performance.
Oh, and you'll like the Quaife too.
Mocha 1978 911SC. "Coco"
Old 09-29-2003, 03:23 PM
I've had mine for about 6 months. During normal driving (street), you won't know it's there. I only notice a substantial difference around turn 7 at Road Atlanta and during Auto-x. I expect to notice an improvement at Barber next month coming out of the hairpin and corkscrew. Anywhere you're on hard throttle coming out of a tight corner, you'll appreciate it. I do not notice any appreciable increase in understeer.
Mike
89 Carrera 3.6 V-ram #94
Livin' for Targa time!
Want to make God laugh?
Tell him your plans!
Old 09-29-2003, 03:42 PM
Thanks guys - I'll report back when its fitted and given a run.
Cheers - Ryan
Cheers, Ryan
1969 911E (historic racer)
911ST replica (tarmac rally)
Old 09-29-2003, 04:43 PM
Did you do the LSD installation yourself? I was previously given 'thread response' instructions but would appreciate if there is actually a manual/written documentation I could acquire.
Thanks!
Old 09-29-2003, 04:59 PM
Cab - nope, I bought a gbox with a LSD in it, pulled it apart, then gave it to my mech and said "pls put it back together with whatever new bits it needs" It is soon to be swapped for my existing gbox
Cool thing was I assumed it was a ZF (and paid accordingly) but ended up with a Quaife!
Cheers, Ryan
Old 09-29-2003, 05:10 PM
pwd72s's Avatar
Tune in...turn on...er, forget the last part. Given the choice of keeping my orignal ZF or installing a Quaife, no price diff. to me? I kept the ZF, but that's just me...
Old 09-29-2003, 06:59 PM
Trust Me's Avatar
Once had a lawnmower talk to me. Said my hand was doomed? Now that's LSD!
Troy
72' 911 T
97' Boxster
81' SC coupe / sold
76' slant nose
81' SC Targa / sold
77' s / sold
67' 912 / sold
89' 944 / sold
74' 914 / sold
71' 914 / sold
Old 09-29-2003, 07:27 PM
jluetjen's Avatar
FTY - A Quaife is not a Limited Slip Differential but rather a Torque Biasing Differential. Both terms are pretty accurate about describing their effects vis-a-vis each other. I agree with the descriptions given above, so I'm not going to repeat them.
John
'69 911E
"It's a poor craftsman who blames their tools" -- Unknown
"Any suspension -- no matter how poorly designed -- can be made to work reasonably well if you just stop it from moving." -- Colin Chapman
Old 09-30-2003, 05:15 AM
poorsha's Avatar
None of us can remember the 60's (or 70's and early 80's).
Thank you Mr. Leary.
78 911SC sunroof Coupe (SOLD)
97 328i Convertible
Old 09-30-2003, 06:32 AM
Double Trouble
targa911S's Avatar
What? Huh? Had a picture on the wall play cello once. He was playing the overture from Tommy.
I used to be addicted to the hokey pokey..........but I turned myself around..
75 914 1.8
2010 Cayenne base
Old 09-30-2003, 06:54 AM
Agree, more understeer, you'll just use more gas to compensate. Also agree that the Quaife and their ilk are more suited to autocross than track use. Clutch type is better for a track than autocross.
Old 09-30-2003, 07:54 AM
beepbeep's Avatar
My understanding is that clutch one is marginally better on trailing throttle and braking but it also wears with time and gradually loses it's diff-braking ability where Quaife unlocks on braking but doesn't have clutches that wear out. Now White Rabbit is probably the best if you can find one...
Thank you for your time,
Old 09-30-2003, 09:19 AM
I agree with Mike above. I swapped out my open diff for a quaife at the same time as a dose of hp upgrade to the motor. I really notice it when stepping on the throttle out of a turn. It really dig's in now.
Old 09-30-2003, 09:27 AM
ZF type LSD's come in different flavors of lockup. The earlier ones only locked up under acceleration. The later ones lock up under acceleration and deacceleration to varying percentages. Depending on the Hp output of your car is how much lockup you want to use. For example, the 917's use a spool thus eliminating a diff. Now for a regular car that would be a waste since most cars don't have the Hp to take advantage of this. ZF's will decrease tire life but if used correctly will drastically reduce laptimes. The added advantage of locking under deacceleration gives the benefit of more stable trail braking in a 911 which in turn allows you to go into a corner deeper. In many ways a Diff should be considered part of the suspension and will need to be considered in the setup.
Cheers, James
You will never know the feeling of a driver when winning a race. The helmet hides feelings that cannot be understood.
Ayrton Senna
1993 964 RS
Old 09-30-2003, 09:45 AM
Exactly, though I've never heard of a ZF that operated on acceleration only. Lockup %s of from 20-80% are common the former is more street oriented the latter for track only. The newest twist that I alluded to is the different factors on acceleration and decelereation that are available in the G50 and newer diffs. 40/60, 80/100 20/40 etc. are even better on the track.
While it's true that the ZF clutchs do wear, the Quaifes have their own reliability issues. Carrol Smith has advised agaist them for track cars in his Tuning series. Though I think that they are fine even desireable for A/X and street use.
Bill Verburg
Old 09-30-2003, 11:08 AM
Mr9146's Avatar
I would go with the ZF because I am a fan of OE ... Quaife might be better, but I personally don't care. JUST MY IDIOTIC OPINION.
Also, the White Rabbit is highly overrated ... I am a BIG fan of Alien Juice (it's a modern thing, don't ask how I know) or Window Payne <-- a friend's mom had some left over.
Also ... tune in, turn on, drop out.
Old 09-30-2003, 11:17 AM
Here is an excellent article addressing Porsche Limited Slip Diffs.
Limited Slip Article
Cheers, James
Ayrton Senna
1993 964 RS
Old 09-30-2003, 11:28 AM
