The driver side front trunk strut is the more difficult to replace. The problem is getting the pin into the hole. First prop the lid up high so you have easy access to the bottom mounting hole. The get a small needle nose vice grip to hold the head of the pin so you can insert it into the hole and with the other hand attach the clip.
5String
+1 on doing whatever you can to secure the parts - those little pins and clips - so that they don't fall down behind the engine, never to be seen again. When I did mine, I looped light pieces of twine around them so that when I dropped them, I could easily retrieve them. Worked like a charm.
5String Tell not a soul that you have seen me; breathe not a word of what I say.... The Northwest Files |
Ok, I must be doing something wrong, I cant find the part #. I need to replace the hood struts on my 89'.
Thanks! Rod
1989 911 Targa M491 1980 Triumph TR8 (sold) 2006 BMW M3 (Interlagos Blue) |
Here is the part number for the Weltmeister HD front hood struts Part #: C-511-331-HD
Mike 1986 930 |
