Nice bar Matt, which one is it? Was it an easy install?
TIA, Rick
Rick '76 Carrera 3.0, track '77 3.2 targa, back home '95 993 C4 M030, SOLD PCA San Diego |
Irrationally exuberant
The old Weltmeister advertisements for their strut braces said that when they measured it, they found the shock towers moved outward under cornering causing a loss of camber. Then they sort of gave the game away:
One might ask why you see them on 964/993's and club racers. The 964/993 coil over struts are putting a lot more strain on the strut towers than a torsion bar 911. In the case of coil over cars I bet it makes more of a difference than earlier cars. Stock class Club racers run them because they are a legal way to crank in more negative camber than the stock strut towers would normally allow. You can physically pull the struts closer together to increase negative camber. -Chris
'80 911 Nogaro blue Phoenix! '07 BMW 328i 245K miles! http://members.rennlist.org/messinwith911s/ |
Rick,
My strut brace is made by Racebred Auto Repairs in Melbourne. The proprietor of Racebred is also my mechanic. Fitting it took some fiddling as one of my shock towers had moved slightly from years of racing. The brace cost me $850 AUD, which works out to be approx. $500-600 USD. It's a quality brace. Matt Holcomb MFIWDP 1974 911 Carrera 2.7 (RoW) Dedicated Homepage Engine Rebuild Homepage Pelican Gallery Profile |
drag racing the short bus
[QUOTE]Originally posted by Matt Holcomb
[B]Rick, $500-600 USD. It's a quality brace. Matt Holcomb But damn, Matt: that's a chunk of change for a bar... I've considered, off and on, a full cage. Gives the chance to run more fiberglass, i.e. the doors.
The Terror of Tiny Town |
Everything here is Aust costs normal price x 10. The price of cars is even scarier.
Ash
'70 911E tangerine coupe (Ash's car) '71 911T viper green targa (Trac's car) - Sold |
I´ve made measurements of the tower movement with a laserpointer fixed at the main bar, pointing on a sheet of mm-paper on the trunk floor, taking a digital video of the laser point while driving a slalom course.
Without triangulation the tower movement has been about 3mm, with mounted diagonal brace the movement was reduced to 1mm. So triangulation seems to make sense in torsionbar-cars, i could also feel less understeering with triangulation. The strut brace i used for that was from elephant racing. Bernd |
David,
I have no doubt that I took one for the team when I said yes to the strut brace. Matt Holcomb MFIWDP 1974 911 Carrera 2.7 (RoW) Dedicated Homepage Engine Rebuild Homepage Pelican Gallery Profile |
The Weltmeister strut bar and SSI's are the only two "updates" I've performed that had a noticeable effect on performance. The bar tightened up the front top end noticably.
The outside wheel in a turn, hitting a decent bump/hole, sends a shock through the A-pillars that's disconcerting. This weekend I am rebuilding my entire front suspension since the bar shows the age of the Boge strut inserts. I'm replacing these and all rubber a-arm bushings, sway bar bushings, ball joints, tie rod(s), wheel bearings, and fasteners. Probably will turn into a bigger project than I anticipate. Especially the wheel bearings. Bob
Bob S. '87 911 ("Hardtop" per neighbor) |
-Chris
I would argue that coils or torsion bars make no difference. True, the coils carry the weight of the car at the top of the tower. However the force vector of the coil is colinear with the strut, it is not attempting to move the top of the strut horizontally. In other words, the coil is pushing perpendicular to the strut brace(nearly straight up), and isn't attempting to push the tower horizontally.
Chuck Moreland - elephantracing.com - vonnen.com |
Information Junky
I would then argue that you have over simplified the differences between coils or torsion bars, and their respective (different) load paths thru the geometry of the structure. . .but I won't.
Everyone you meet knows something you don't. - - - and a whole bunch of crap that is wrong. Disclaimer: the above was 2˘ worth. More information is available as my professional opinion, which is provided for an exorbitant fee.
How is the coil creating anything other than a colinear force?
"with a laserpointer fixed at the main bar, pointing on a sheet of mm-paper on the trunk floor, taking a digital video of the laser point while driving a slalom course."
-- Very clever! I love the low buck science in it. Most would have spent $$$ on a strain gage and datalogger - or even more on laser interferometry. But you compared no bar witha triangulated bar, right? Did you make a comparison with a simple straight tie bar? Also, what year car was it? |
How about welding mounts to the insides of the trunk, and making a bolt-in brace, that could be removed if need be?
I've also seen cars with a simple tube welded across.
"You go to the track with the Porsche you have, not the Porsche you wish you had." '03 E46 M3 '57 356A Various VWs |
The simple single-member brace yielded 3mm movement, the triangulated brace yielded 1mm. The last time I discussed it with him, he had not performed the test on a car with no strut brace. In fact his setup used the main brace to hold the laser. His car is an 80s Carrera.
So using a single-bar ER brace (sez Chuck), you get 3mm movement (sez Bernd) which equates to 0.38 deg camber change (sez Chris). Presumably using no brace at all you get more than 0.38 deg camber change (sez me). Is there then even more camber change from the rubber upper strut mounts - who sez?
1989 3.2 Carrera coupe; 1988 Westy Vanagon, Zetec; 1986 E28 M30; 1994 W124; 2004 S211 What? Uh . . . “he” and “him”? |
![]() Just think about where the force goes beyond where the spring contacts the perch. The various body parts spread out at various angles through metal of different size and strength. Try this: Put your elbow on the table with your forearm pointing straight up, then bend your hand horizontal at the wrist so you have an inverted "L". Keep your wrist locked and push vertically on your fingers the way a spring would; it's not the same structure as a shock tower but demonstrates how the loads get distributed. EDIT: Oh yeah, I forgot to mention to remember the kind of chassis bending vertical force that comes from a stiff shock when you smack a bump. I'm guessing that it can easily go beyond an order of magnitude more stress than springs produce. Last edited by thabaer; 10-10-2003 at 02:33 PM.. |
Thanks, Chuck.
Now we need to figure out what the extra 2 mm means in terms of handling feel, rigidity, and suspension alteration....?? |
As Chuck said, i only compared single brace / triangulated brace, because i didn´t see a possibility to measure without any brace in that simple way.
Car is a ´89 convertible. The differences between no bar / single bar / triangulated bar are really obvious while driving only a few meters on the street. Regards, Bernd |
