CHILI's Avatar
Maximum height difference of Adjustable springplates
Does anybody know the maximum height difference you can get from an adjustable springplate that's set in the middle?
Example: I just installed them and have them set in the middle (as recomended), but my car is 1" too high on one side and about an inch and a half too high on the other side. Do I need to re-index the T-bars, or can I get a 1 inch change using the adustable spring plates? And, yes, I drove it around to settle it in
Thanks for any thoughts.
"I understand that you want to drive fast, it's just that I want to go faster!" Move ova please
Chad aka "Chili"
1974 Base coupe in Carrera outfit.
No A/C, no Sun Roof, no power windows. Fast and light, just the way I like it. (Sad to say, it's sold. But at least it remains with us on this board.)
My car http://www.pelicanparts.com/gallery/CHILI
1969 RSR Project. Heavy on the word PROJECT! No pictures yet. Keeps breaking lenses of cameras.
Old 10-09-2003, 04:49 PM
CHILI's Avatar
Anyone? I don't want to take the springplates off unless totally necessary, but I also don't have large enough wrenches to fit the backside of the adjustment bolts. I used a large crescent wrench (cheesy, I know) while they were out, but it won't fit in-between the tub and the springplate.
Will a normal open end fit, or is it a special tool?
Chad aka "Chili"
Old 10-09-2003, 05:57 PM
SRISER's Avatar
You need a special 36mm thing wrench that Pelican sells for about $28 bucks. The eccentric will lower the back of your car about .75-1.0 inches. Anything more and you are re-indexing.
Sam
'02 996 TT
'07 Audi S4 Avant
'88 Carrera (Sold)
Old 10-09-2003, 06:09 PM
Friend of Warren
Like Sam says anywhere from 3/4"-1", but sometimes even less. And you don't need to buy a $28.00 plus shipping wrench. Just head down to your bicycle shop and ask for a 36mm headset wrench. Cost you around $10.00. It works just as well, maybe even better than the Porsche wrench.
Kurt V
Old 10-09-2003, 06:18 PM
CHILI's Avatar
Thanks guys! Looks like I'm re-indexing today
Man, those Netrix bushings are a biatch to get in. I don't want to do it again, but oh well. I'll get it right this time.
Thanks for the tip on the wrench. I'll check it out.
Chad aka "Chili"
Old 10-10-2003, 09:46 AM
Chad,
Are you doing this without and angle finder or Wil Ferch's instructions????
Neil
'73 911S targa
Old 10-10-2003, 11:30 AM
Having just gone through this (but made much easier w/ poly-bronze bushings), you're definitely going to have to re-index. If the spring plate adjustment is in the middle, you're only going to get maybe 1/2 - 3/4" (if that much) either way. Good luck!
Old 10-10-2003, 11:37 AM
