Senior Member
Followup questions after reading Pelican suspension posts.
I've assembled a binder full of every front and rear suspension thread on Pelican. I'm doing this to get a complete top-down look at the job at hand. We are darn good I have to say!
But I do have a few questions about threads that seemed to be left open-ended. Here are my questions: = Wedge bolt: Did we ever decide that the "old" profile wedge bolts are NLA? That Pelican and others only supply new profile (shorter, more bolt sticks out of wrong end) wedge bolts? = Using long M8 bolts to pull in rear torsion bar cover: Anyone do this other than the original poster? Required to pull cover over bushing? = Sport/HD Bilsteins matched to Tbars: Is there any graph or urban legends showing what tbars match what Bilsteins? = Oil in strut housing: Did we decide that oil in the strut housing was to quiet potential rattle or was this rather a failing strut insert giving up its life blood? = Warren recommends Valvoline #985/986 SynPower Synthetic grease for steering rack relube. Anyone have any differing lubes? = The spacer that comes with the turbo tie rods: Does anyone actually use this? Why was it included? Many, many thanks for helping me tie these loose ends together! John
'78 Targa in Minerva Blue |
Re: Followup questions after reading Pelican suspension posts.
Chuck Moreland - elephantracing.com - vonnen.com |
Neil '73 911S targa |
My understanding is that the only strut that you should expect to see oil in is the original Boge struts, all others should be dry.
The spacer in the turbo tie rod kit is to keep from damaging the rack as I understand it.
John,
Actually, the rear bushing covers are held on using M10 bolts ... and yes, a couple of different-length longer bolts can aid installing covers over new bushings! The spacer in the Turbo tie-rod kit is to keep the threads from bottoming out in the rack ... there is a definite gap between the end of the rack and the Turbo threaded joint if you don't put the spacer in place! Original KONI struits have hydraulic oil in the housing, since the strut housing serves as the outer tube of the assembled strut, and struts don't work well without the oil for dampening! For installation of replacement KONI inserts, glycol anti-freeze is recommended to be put in the strut housing for heat dissipation purposes.
Warren Hall, Jr. 1973 911S Targa ... 'Annie' 1968 340S Barracuda ... 'Rolling Thunder' |
SCWDP- Shock and Awe Dept
You maybe able to get some more specific info if you lay out your plans but it looks like you have all the info you need.
Use the spacer w/ the tierods, otherwise the tierod will bottom out in the rack. Edit: Warren beat me to it! I used the Pelican supplied wedge bolts and they were fine, they just don’t sit almost flush like the old ones. Do not over tighten them or they will break, ask me how I know. There is also conflicting torque specs out there for them, I’m pretty sure Benleys had it right though. Good luck, it’s fun and very well worth it!
Ryan Williams, SCWDP '81 911SC Targa 3.6 '81 911SC Coupe 3.2 #811 '64 VW Camper Bus, lil' Blue |
After being dis-satisfied with the wedge bolts that Pelican shipped me (two sets actually), I did order some from a local Porsche dealer (the only thing I've ever sourced locally), and those matched the taper of the originals, and did fit flush with the strut. This was just a few months ago. ps. Although the wedge bolts that Pelican ships may be OK, I was not comfortable with the fact that about 3/16" of the skinny threaded portion of the bolt would be in the ball joint shaft notch instead of the tapered portion as the originals are. Someone mentioned their concerns about these bolts passing a track inspection, but I don't know about that...I just knew 'it wasn't right', and several local p-car folks agreed w/ my safety concerns. Last edited by KFC911; 10-14-2003 at 10:26 AM.. |
Licensed User
Senior Member
Thanks very much guys!
I am going to 21/26 w/ Sports, and now I am wondering if that is not such a great idea? TargaSC with maybe a DE or two in its future. Again, many thanks for these (and future) responses, John
Schleprock
Kevin L '86 Carrera "Larry" Last edited by KTL; 10-14-2003 at 01:34 PM.. |
Like Kevin, I too followed Steve Weiner's advice. I think the key is to pick a 'known' combination that works well in unison, and Steve has plenty of experience in this area. I had already upgraded to Bilstein HDs in front, Sports in the rear, so after talking with Steve, I went w/ Sander's hollow t-bars 22 front/29 rear. I don't disagree with Chuck's recommendation either, as there isn't necessarily a right/wrong answer as much as picking a combo that 'works well'. I would also highly recommend Chuck's poly/bronze control arm and spring plate bearings (since you're in there)...and man are they nice! |
