Jacksonville, Fl
Alex Jacksonville, Fl '88 Carrera, Guards Red |
abides.
I wanted to peek inside the fuel tank to make sure my strainer was clear... went to pull the sender out, and the gasket created enough resistance that the top came off without the tube, breaking the wires inside that the float slides on.
There goes $130. At least the fuel tank was clean inside.
Graham 1984 Carrera Targa |
I installed new headlights and wiring, first drive at night the low beam seemed very dim.....I had mixed up the ground and high beam wires causing the lights to run at half voltage :-/
1983 RHD SC 3.0 1994 RHD E31 850 CSi |
The Dude abides...
Oh sweet Jesus!
Steve '03 Carrera 4S |
I like all these posts where the Pelicans reference some stupidity that took place, like 10-15 years ago. For me it's more like every project.
Last year I was looking for a set of aero mirrors and, as my GF and I were departing from Ft. Lauderdale on a weekend cruise, I saw a pair on Ebay. The ad said they came from a LHD car so I quickly consulted the PET but didn't study it close enough to see that there was a LHD part number and a slightly different RHD part number. I ordered them as we were pulling away from the dock (and reliable cell service.) When the mirrors arrived I was in the middle of something else. So when I finally got around to unboxing and installing them, guess what? They were for a RHD car and the deadline had passed for any returns! In case you're curious as to the difference between LHD and RHD, the angle of the bases is different so you can't see the same. Luckily (I guess) I discovered that I could replace the bases to make my RHD mirrors work on a LHD car, so I ordered the LHD bases. They weren't easy to replace due to the spring pressure, but I finally got them on. After I finally got them installed and they had the right angles to be useful, I realized the driver's side has the convex glass and the passenger's side has the flat glass, which is the opposite of most modern cars. So I've spent probably close to $800 on freakin' aero mirrors and still don't have the right glass. |
'88 Carrera Guards Red '70 VW Beetle Yukon Yellow
The Dude abides...
Well, leave it to me to pull this thread from the depths...
Yesterday I spent the better part of the morning troubleshooting (for the upteenth time) my damn license plate lights. My issue is all markers, brake and tail lights working, but no juice to the plate lights. I dissected a taillight assembly, only to find the power is not fed from the assembly on my '87. While checking the fuse (yet again), I notice a disconnected wire hanging below the frunk fuse panel. Could it be??? The wire had broken off, seemingly from a tight set screw and years of corrosion. But had it been attached to fuse #20? Upon loosening the lower set screw on fuse #20 I hear a small piece of wire fall the the floor of frunk. At this point I'm feeling encouraged that I've finally found the problem. After re-stripping the broken wire and reattaching it to the fuse panel, I check the fixture leads and find 12 V!! On to the next simple problem that will take me days/weeks to troubleshoot.
'73 911 T Targa
I have one of those drainpans that can also be used to carry the oil; the kind with a single hole in the center and a spout on the side.
After a nice long drive on a fall day, I decided to change the oil before putting the car up for the winter. I figured the oil was nice and hot and that all the crud was well suspended. What better time to get all of this stuff out of the engine and let the car hibernate with fresh, clean oil. I got the pan under the oil tank and just as I was removing the plug noticed a leaf that had landed in the drainpan. Without a whole lot more thought, I continued to remove the plug. Naturally, the leaf migrated to the hole and covered it. I made one fleeting attempt to get the leaf out of there, burning the three fingers that volunteered to try. After that, i just watched helplessly as the oil lava flow made the mess of the century. Man these cars hold a lot of oil! |
Taking it a part. That was really stupid.
The Dude abides...
Hey, thanks for the commentary, "DR"...maybe we could get together sometime and discuss how stupid it really was...
Quickstep I feel your pain. I forgot to undo the breather on my oil drain pan last time. It took hours to clean up that damn mess.
I removed all four callipers and sent them away for refurbishment.
When I got them back I set the angle on the piston recess and installed them back on the car. I then filled the master cylinder and even went as far as bleeding the system, you would think at this stage Id have noticed the bleed nipples should not be at the bottom, but it wasn't until I realised I was getting no pressure at the pedal that it finally dawned on me. This probably happened because I thought I had a spare couple of hours to work on the car and tried to rush the job.
1984 3.2 cab india red 1970 1192 Volkswagen Beetle |
admit to your stupidity
Been there AND done that, although fortunately never with the SC, unfortunately mainly because I haven't been able to drive it long enough too have to change the oil on it... ![]() There really isn't a way to explain the feeling one has as you watch scalding hot oil creeping towards the top edge of the collector pan, other than...................... ![]() Sent from my iPad using Tapatalk
"What the hell is an Aluminum Falcon??" -Palpatine (Robot Chicken) 1978 911SC Targa Working Projects: 1968 912 Last edited by bugstrider; 02-26-2017 at 12:43 PM.. |
while not on the 911, i was changing the oil on the family hauler (2010 X5). This is a job i've done 5 times on this car alone. If you're familiar with that car, the front differential oil drain plug is about 6 inches away from the engine oil drain plug. In a haste, trying to rush, 11pm on a Friday night, i drained the diff oil instead. first of all it's a completely wrong socket which should have been the first warning but it was meant to be.
Sucked that i had no spare gear oil in the middle of the night. Finished the oil job. went on Amazon at 1am and ordered the gear oil. Got delivered on Sunday and i was back on the road. gotta love Amazon.
2007 GT3 RS Orange/Black 1986 911 Carrera White (dedicated race car #23) |
I put gas in my 72 and broke off the stop that is 4" down the tube - I am an idiot - had to retrieve the small piece of metal from the tank
![]() Installed the wrong return line! Expensive and time suck stupidity. FUCH! |
Banned but not out, yet..
As a public service, that non-constructive ridiculing the poster is really below the belt. We are here to help people out not tear them down. If you need to feel good about yourself by putting others down, there are plenty of other boards.
An air cooled refrigerator. ‘Mein Teil’ |
Going for a quick and easy road safety inspection in november, just before winter in northern Norway sets in. Dry roads when I left the house.
-------- 1977 911s |
