What size wheel spacers?
I finally got a set of fuch"s my tire size's are255/55 16 and 225/50 16. What would be the best size wheel spacer to put on to fill the wheel well better?
bk
Old 10-19-2003, 03:49 PM
Buy them, sell them
Adam's Avatar
It'll help if you can tell us what kind of 911 you're putting the wheels on.
Is it an SC/Carrera or turbo/widebody car?
1931 Oakland Eight Special Saloon
1985 BMW E28 525e (Euro 528e)
1989 911 Carrera Sport 3.2 G50 Cabriolet
Old 10-19-2003, 04:16 PM
Yes I guess it would sorry about that.
1983 sc cab.
Old 10-19-2003, 04:21 PM
Eric Coffey's Avatar
EDIT: Just noticed your tire sizes. What are the wheel sizes? From the tire sizes listed, I assume they are 7's & 8's or 7's & 9's. If that is the case, then you shouldn't need any spacers! If they are 16x6's&7's, then you are running tires that are too big (should be 205's & 225's). Even on a 9" Fuchs, 255 is pushing it. With 6's & 7's (and correct tire sizes), you should be able to go up to 28mm on the rears, with modest camber and ride height (say, -1.5 and 24.75" fender height) without rolling the lips and/or rubbing issues. You can probably run 32mm+ if you are running around -1.8+ negative camber. As far as the fronts go, you can get away with a 7-8mm spacer between the hub and rim. If you go any larger, you will need longer studs.
Old 10-19-2003, 05:23 PM
Administrator
Jack Olsen's Avatar
If you're running 225/255 tires, then I'd assume you have 8-inch (or 9-inch) rear wheels, and probably 7-inchers in front. I don't see why you would need (or possibly fit) spacers with that combo.
What size Fuchs did you get?
Old 10-19-2003, 05:44 PM
HotPorsche's Avatar
BK .... Please let me know what spacers you go with as I am looking at doing the same. I have the factory 6/16 and 7/16 on my 84SC Targa Have you seen the spacers on E-Bay?
Jeff T.
84 911 Targa
Old 10-19-2003, 05:50 PM
When I bought the car it came with 7&8 x16 bbs wheels with the 205/55 and 225/50 tires. Since then I purchased 6 & 7 x16 fuch's and put the same tires on the fuch''s. So should I have
205's & 225's instead? What will the oversize tires o ?
Old 10-19-2003, 06:11 PM
HotPorsche's Avatar
BK ... I just looked at the engine compartment of my 84 Targa. The factory tires are 205-55-16 front and 225-50-16 rear. Sounds like you are in good shape.
Jeff T.
84 911 Targa
Old 10-19-2003, 06:24 PM
thanks for the info I will let you know what I get
bk
Old 10-19-2003, 07:07 PM
