In the shop at Pelican
Jared at Pelican Parts's Avatar
MSD Tach adapter Question
I've been outting a MSD 6A in my cousin's 1983 911SC, just got around to installing the tach adapter, Got everything mounted, except for I dont know what wire in the engine bay goes to the tach and to terminal "TD" any help? I really would prefer to use an existing wire, rather than having to route a new one
Old 10-20-2003, 08:39 AM
The black wire with the purple stripe from the cd box is to the tach. Hope that helps.
Old 10-20-2003, 10:09 AM
Is it located in that connector block at the very rear of the electrical panel on the left side?
Old 10-20-2003, 10:11 AM
If you mean the 14pin harness connector then I'm not sure. When I swapped the 3.0 for my 2.7 I couldn't get my tach to work. I found that the black wire with purple stripe from the cd box was grounding out in the 14pin connector. I removed it from that connector and spliced it into the 2 wire connector by the cd harness, one is red for something else while the other is for the tach. Now it works fine. Souk seems to know a lot about these, so if your still stuck pm him.
Old 10-20-2003, 10:18 AM
Eugene at Pelican Parts's Avatar
These are the two threads I used to install my Crane HI-6, Jared:
MSD Install Notes for SC
MSD wiring advice (connectors)
Are you sure a tach adapter is necessary for that SC? Let me know if you get stuck.
Eugene (Formerly) at Pelican Parts
Pelican's E-Commerce Guy, 2003-2011
2001 330i Sport
1983 911SC Coupe (sold)
Old 10-20-2003, 10:40 AM
Unoffended by naked girls
dhoward's Avatar
Send a message via AIM to dhoward
A tach from a 79 works using the tach output on the MSD box. Try that before you buy an adapter.
Dan
1969 911T (sold)
2008 FXDL
www.labreaprecision.com
www.concealedcarrymidwest.com
Old 10-20-2003, 10:48 AM
I already have the adapter. So basically i just have to look for the black/purple wire under the engine relay board, then splice the tach adapter lead in, right?
Old 10-20-2003, 10:50 AM
Like others, I wanted to keep the old wires untouched and retain the factory 6-pin harness, so I got some male spade connectors from Fry's and plugged them right in. A splice is definitely more reliable, but I'm not concerned about the plugs coming loose.
2001 330i Sport
Old 10-20-2003, 11:06 AM
I ran out to the car on my lunch break and spliced the tach adapter lead into the black/purple wire on the 14-pin connector and success, tach now works. Thanks guys
Old 10-20-2003, 03:27 PM
