Throttle linkage switch q?
I've noticed on my SC that there is a small switch that I assume is meant to be tripped when the throttle linkage @ the engine returns to its idle point. Mine doesn't quite return enough to activate it, so I just finessed the switch lever a little & now it does.
What does this switch do? I tried to follw the wires but they go to parts unknown at the front of the engine? Does anyone know?
thankyou
Old 10-25-2003, 02:38 PM
bumper....
anyone know?
Old 10-26-2003, 05:28 PM
Double Trouble
targa911S's Avatar
on the MFI cars it is a fuel cut off switch to eliminate backfire on deceleration. Can we assume it is the same on CIS cars?
I used to be addicted to the hokey pokey..........but I turned myself around..
75 914 1.8
2010 Cayenne base
Old 10-27-2003, 05:55 AM
hbf hbf is offline
Do a search on "cold start valve" on this BBS. Lots of discussion in the past.
HBF
Old 10-27-2003, 08:20 AM
Thanks. Found it:
Throttle Closed Switch
Thank god the search function is up & running! My life is complete again.
I haven't noticed any difference now that I have the switch correctly set. THe weather has been v. hot though.
Old 10-27-2003, 09:11 AM
update- the proper operation of this switch seems to have eliminated a tendency for the engine to die when revs drop when its cold. eeeexcellent!
Old 11-11-2003, 08:15 AM
