Rennch on YouTube
rennch's Avatar
Send a message via AIM to rennch Send a message via Yahoo to rennch
Left turn signal on SOLID...what to test?
Hi,
My left front turn signal, when I turn my lights on, is in the ON position...SOLID. When I activate the left turn signal from inside the car, it works in the rear, and the dash indicator sort of blinks bright on the left arrow, and dim on the right arrow. What should I check/test?
*I'm an electrical novice...just got my first multitester on Tuesday.*
From the looks of it, I'll be an expert by the time this car is done!
mto
Michael O'Neal -
69 RSR Clone(ish) - The build: http://bit.ly/69porschersr
69 911S Blasphemy Build on YouTube
Rennch Youtube Channel: http://rennch.com/Youtube Instagram: https://www.instagram.com/_rennch_/
Old 11-09-2003, 09:59 PM
Free minder
Aurel's Avatar
Do you know that if you leave your trun signal on and shut down the car, your blinker will stay on SOLID on the side you left the turn signal ?
Isn`t that what you are experiencing ? It is a normal feature of the 911...
Aurel
1978 SC Targa, DC15 cams, 9.3:1 cr, backdated heat, sport exhaust https://1978sctarga.car.blog/
2014 Cayenne platinum edition
2008 Benz C300 (wife’s)
2010 Honda Civic LX (daughter’s)
Old 11-10-2003, 03:49 AM
What?!?!
DonDavis's Avatar
Bad ground connections will make you go batty! While chasing the turn signal circuit and you come upon a ground, even if it "looks" good, take it apart, clean and reconnect securely. Then chck it off the list as done.
The fuse block could probably use some attention as well. There's also the turn signal relay.
Good luck.
running shoes, couple tools, fishing pole
1996 Subaru Legacy Outback AWD, 5speed
2002 Subaru Impreza WRX, 5speed
2014 Tundra SR5, 4x4
1964 Land Rover SII A 109 - sold this albatross
Old 11-10-2003, 06:53 AM
bigchillcar's Avatar
emotyo.
i spent over a year trying to track down a similar turn signal indicator problem...checked all wiring/grounds at the four corners. finally, i replaced the turn signal relay....voila! no more problem.
ryan
To the memory of Warren Hall (Early S Man), 1950 - 2008
www.friendsofwarren.com
1990 964 C4 Cabriolet (current)
1974 911 2.7 Coupe w/sunroof 9114102267 (sold) 1974 914 2.0 (sold)
Old 11-10-2003, 07:08 AM
Rennch on YouTube
rennch's Avatar
Ok folks...thanks for the advice. Looks like I've got a few things to look into!
mto
Michael O'Neal -
Old 11-10-2003, 07:17 AM
JC930's Avatar
Are the bulbs good front and back?
77' 930 turbo carrera silver SOLD
03' SL500 Mercedes Benz white
06' GMC Yukon Danali white
15' LTZ Chevy Suburban black
07' 997 tt black
Old 11-10-2003, 07:25 AM
Rennch on YouTube
rennch's Avatar
Yes, they were replaced fairly recently.
Michael O'Neal -
Old 11-10-2003, 07:46 AM
Send a message via AIM to fintstone
Do your horns work normally..with your lights on and off? What about with the left turn signal on/off?
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo
http://www.pelicanparts.com/gallery/fintstone/
"The problem with socialism is that you eventually run out of other people's money"
Some are born free. Some have freedom thrust upon them. Others simply surrender
Old 11-10-2003, 10:24 PM
Cool
I don't know much about the left/right/no key/ circuit.. other wise
I'm the 3rd to bet on the relay........Ron
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 11-11-2003, 12:34 AM
I would take that bet...seems to me that he has lost his headlight ground and it is grounding back through his turn signal light (or he has gotten that wire switched at the back of his headlight only if he has worked on the wiring in that area already). Of course, if that is the case, the relay won't last long either and soon he will lose all turn signals.
Old 11-11-2003, 08:00 AM
Cool
yeah. it could be a ground..
but I have 3 used sets of rocker shaft bolts, nuts and washers against your.. Uh?
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 11-11-2003, 08:09 AM
Ha! Sorry, don't need those. My reasoning is that the same relay pin out runs all the signals. If one works, they all should and the flasher is good. The flasher is so simple to test, that it is easy to eliminate.
Old 11-11-2003, 08:58 AM
